Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 81
    #61
    naalala ko may post si stigg ma tungkol sa equipment na ginagamit ng mga gas station
    kailangan visible daw sa public para malaman kung bago o di kinakalawang or something like that
    hanggang doon concerned siya
    jusko
    ... external-minded...
    Sep 2016
    #62
    Bukas schedule ko ng PMS. Dun ulit ako sa service area kasama technician habang yung ibang clients eh nagchichill sa lounge.
    Jan 2008
    #63
    Diba most casas now have CCTVs? Hinde ba uubra yan hinde gagawin plus if it's just regular PMS, sobrang bilis lang yan para hinde nila gawin. Everybody doon sa shop dapat kakuntsaba nila which is impossible.
    One way siguro is for them to be transparent.. para walang tinatago at hokus pokus... hehe
    If its late, its free..
    sa gas station,
    katabi ako ng mekanikong nag-change ng oil and oil filter.
    wala pang pila at waiting time.
    and the price is right.
    sa banawe in front of auto parts store
    sa parking space ginagawa ang kotse
    i watch the mechanic work
    nakikialam pa ako parang gusto nila sabihin "ikaw na nga gumawa" hehe
    Jul 2013
    #65
    naalala ko tuloy bigla yung friend ko na may car detailing shop pero di naniniwala sa ceramic coating
    none of his cars are ceramic coated.
    lahat naman daw kasi ng car kapag binuff mo, kikintab
    as for the protection... sino naman maglalakas loob to see if may naitulong daw yung coat
    #66
    years ago, along evangelista makati,
    ako pa ang nagtuturo sa "mekaniko" kung ano at paano ang gagawin...
    i haven't gone back to evangelista since.
    also, walang paradahan most of the shops there.
    sa banawe, merong parking space yung suki ko.
    Jan 2008
    #67
    Pwede yan ma test, buy ng car panel then try different brands.. hehe
    I watch sa youtube yung channel ni projectfarm.. may mga test sya dun ng spray wax.. pati yung turtle wax ceramic spray wax
    #68
    yes,
    it's cheaper and easier in youtube.
    but one does have to be aware of... bias reporting.
    Jan 2008
    #69
    Yes yes.. pero maganda test methods ni projectfarm.. not sponsored and tries to remove all bias sa test.. makikita which brands perform across the price range.. surprising that some cheap brands are way better than expensive brands..
    Kaya ok din minsan reviews ng mga shop.. at least we have an idea on their performance.. madami din nasilip here sa tsikot ng feedbacks sa isang shop eh..
    mga mekaniko kasi akala nila walang alam mga customer sa kotse
    kaya you need to make it known to them may alam ka para di ka bolahin
    recently i helped a friend whose car had a coolant leak
    a mechanic quickly concluded kailangan palitan ng water pump even without checking thoroughly
    sabi ko silipin niya mabuti coz the leak isn't coming from the pulley side of the engine
    ayun the leak was coming from this (encircled):
    #71
    the thermostat gasket? cheap fix.
    i once had this sentra with mysterious chronic loss of coolant. (different story from my aux fans.).
    it was a young mekaniko, who finally traced it to a leaking finger-size length of rubber hose. it was hiding under the intake manifold.
    had the engine been installed in the classic manner of olde RWD and not FWD-style, that hose would have been very visible.
    this part:
    it's made of plastic
    meron crack
    #73
    this part:
    meron crack
    because it's plastic,
    is it safe to assume,
    it's cheap?
    matapos palitan ung part, nag ilaw ang check engine
    the mechanic said "kusa mawawala yan"
    wtf
    sabi ko no, i-trace niya lahat ng ginawa niya
    baka meron siya nagalaw na socket ng sensor
    ayun meron isang socket di nasaksak
    it's cheap?
    yup mura lang compared to the price of a new water pump
    #76
    wtf
    my pet peeve,
    "bakit kulang nang turnilyo ito?"
    sa tyre shop,
    whenever i ask for a plastic valve cover, they always readily give me one.
    obviously, that cover comes from somewhere... old pitos?
    Jul 2013
    #77
    anyway. so far, ok naman ako sa Honda Makati. my only complain is that naka tutok sa driver yung vents ko tapos full blast yung AC when its time to pick-up the car.
    funny story (last July lang) I remembered when I saw the tire rotation story...
    I told the SA to replace 1 rear mags, na-gutter kasi ni misis. then I asked them to just leave the old mags (yung may gasgas sa trunk)
    Tech 1 - rotated my tires
    Tech 2 - replaced the mags sa likod as per the job order
    3pm tumawag si SA na ready na car ko for pick-up
    3:10pm tumawag ulit si SA. he was checking the job done and asked me kung bakit ko daw pinapalitan yung rear mags. kasi yung nasa harap ung puro gasgas. I told him, iisa mags ko na may gasgas! so malamang sila naka sira nung front mags ko.
    then he checked the trunk...
    pinalitan nila is yung maayos na mags
    Jul 2014
    #78
    Sabi ng mekaniko d daw pwde ung oil ko kasi pang diesel. Sabi ko API SN yan. Sabi niya ayan o diesel engine oil. Buti nag buttin ung may-ayi sabi pwde yan. Naging maayos naman ang lahat at babalik pa rin ako sa shop nila.img20221207111832.jpg
    Sent from my CPH1911 using Tsikot Forums mobile app
    #79
    3:10pm tumawag ulit si SA. he was checking the job done and asked me kung bakit ko daw pinapalitan yung rear mags. kasi yung nasa harap ung puro gasgas. I told him, iisa mags ko na may gasgas! so malamang sila naka sira nung front mags ko. then he checked the trunk...
    i wonder,
    instead of verbally giving instructions,
    would it help if we gave them a piece of paper on which is written in very clear letters, exactly what we want done?
    with ordered numbers, even?
    #80
    Quote Originally Posted by Mask Rider Blac View Post
    back in the day,
    we used to experiment with our traditional non-electronic engines, using diesel oil with appropriate characteristics naman, in lieu of gasoline engine oil.
    ok naman.
    but we tired of it, and eventually just followed the crowd.
CASA Car Dealership Horror Stories
