Results 71 to 80 of 81
- 52,731
December 7th, 2022 11:52 AM #71the thermostat gasket? cheap fix.
i once had this sentra with mysterious chronic loss of coolant. (different story from my aux fans.).
it was a young mekaniko, who finally traced it to a leaking finger-size length of rubber hose. it was hiding under the intake manifold.
had the engine been installed in the classic manner of olde RWD and not FWD-style, that hose would have been very visible.
December 7th, 2022 12:03 PM #72
- 52,731
December 7th, 2022 12:07 PM #73
December 7th, 2022 12:12 PM #74
matapos palitan ung part, nag ilaw ang check engine
the mechanic said "kusa mawawala yan"
wtf
sabi ko no, i-trace niya lahat ng ginawa niya
baka meron siya nagalaw na socket ng sensor
ayun meron isang socket di nasaksak
December 7th, 2022 12:14 PM #75
- 52,731
December 7th, 2022 12:16 PM #76
December 7th, 2022 12:26 PM #77
anyway. so far, ok naman ako sa Honda Makati. my only complain is that naka tutok sa driver yung vents ko tapos full blast yung AC when its time to pick-up the car.
funny story (last July lang) I remembered when I saw the tire rotation story...
I told the SA to replace 1 rear mags, na-gutter kasi ni misis. then I asked them to just leave the old mags (yung may gasgas sa trunk)
Tech 1 - rotated my tires
Tech 2 - replaced the mags sa likod as per the job order
3pm tumawag si SA na ready na car ko for pick-up
3:10pm tumawag ulit si SA. he was checking the job done and asked me kung bakit ko daw pinapalitan yung rear mags. kasi yung nasa harap ung puro gasgas. I told him, iisa mags ko na may gasgas! so malamang sila naka sira nung front mags ko.
then he checked the trunk...
pinalitan nila is yung maayos na mags
December 7th, 2022 12:29 PM #78
Sabi ng mekaniko d daw pwde ung oil ko kasi pang diesel. Sabi ko API SN yan. Sabi niya ayan o diesel engine oil. Buti nag buttin ung may-ayi sabi pwde yan. Naging maayos naman ang lahat at babalik pa rin ako sa shop nila.
Sent from my CPH1911 using Tsikot Forums mobile app
- 52,731
December 7th, 2022 12:29 PM #79
- 52,731
December 7th, 2022 12:34 PM #80
high idle RPM at engine start
