i\m not sure if this is supposed to be here or somewhere else, move na lang if it's in the wrong section.
i'm currently in the process of disassembling my old desktop PC, getting all sorts of cables for it, and eventually installing it in the car. since the old ATX case is too big to fit sa left rear side ng pajero (opposite where the 2nd aircon motor is), i'll be scratchbuilding a case probably using high-impact acrylic or something. anyone know the phone number of Joli's near UST and what time they open? they might be the best place to go for that kasi.
also, which shop can you recommend to make a sort of battery terminal block connector kasi i need to hook up pala the inverter (12V DC to 220V 400W AC) directly to the battery if it'll use 400W (300W yung power supply ng PC ko). the supplied alligator clamp is...not confidence-inspiring kasi, so i thought of having a custom connector na lang to the battery.
thanks!
