Results 1 to 6 of 6
- Feb 2009
- 2
February 21st, 2009 03:55 AM #1newbie lang po ako d2,need advice from you guys
may problem po ako sa owner type jeep,4k ang engine nya,pinalinis ko yung carb kc nung nakuha ko sya,walang syang air filter,ok naman yung takbo nya ng walang air filter,nilagyan ko ng air filter,to be sure pinalinis ko na rin yun carb,kaso parang lumakas sa gas at namamatay sya sa pag shift ng gear,medyo makalog din yung engine (sa idle) at may backfire pa,need your help on this po.advice na pwede ko gawin para maayos muna,thanks in advance po mga sir
napalitan na rin po yung fuel filter
- Feb 2008
- 577
February 21st, 2009 05:12 AM #2anong linis? spray carb cleaner lang or overhaul?
kaya pa ba ma-adjust yung carb? kung di kasi ma-adjust, baka worn rings na yan at kelangan na i-rebuild. go to a&m kamuning and look for elmer
February 21st, 2009 06:32 AM #3
check the valve timing.. check yung contact point.. baka mababa yung idle niya
- Feb 2009
- 2
February 21st, 2009 08:14 AM #4
overhaul cleaning po ang ginawa,medyo makalog nga po yung makina,then i try to adjust it pero pag tapak sa pedal (gas) parang naiiwan yung accelaration ng gas,pag restart naman after i adjust ang taas naman ng menor,meron po kayang part na di naiayosor maliwag sa loob ng carb? baka kc may way pa para maayos ko muna bago dalhin uli sa mechanic,medyo hirap din ako papuntahin yung mekaniko kc lang wala sa bahay
thanks po sa reply nyo mga sir,baka may iba pa way to fix the issue
February 21st, 2009 12:44 PM #5
February 21st, 2009 09:33 PM #6
Dear Digs1:
The behavior you are describing sounds like a lean flat-spot, on transition from curb idle to main jet operation. It appears that the person who overhauled your carburetor did NOT know what he was doing.
Did you save the carburetor parts from the overhaul? You may need them to restore performance.
Let me give you the full benefit of my experience when I say to you
"If it AIN'T BROKE, DON'T FIX IT!".
When you decide to overhaul a carburetor, make sure you have the correct parts and overhauling kit or you're in for trouble. You should also make sure the person undertaking the job really knows what he is doing.
Also a routine repair is not the time for you (or your mechanic) to learn how to fix carbs.
The agreement should be that if he can't make it work right, no PAY!
There are too many unscrupulous individuals out there taking advantage of people.
Try some of those guys near Kamias or Kamuning.
Dusky Lim
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
