i am currently trying to fix my ae92 car with a 4af engine. this car has been relatively idle for 4 years.
i decided to change the carb with a surplus when i got fed up with the idling issues.
the surplus carb was fine and the engine run a lot smoother. however, when i tried to drive the car, the engine stalled and i was not to start it since then.
my first guess was the tank ran out of fuel to I bought some 4 liters of fuel. i put some gas on the carb and started the engine. it seemed that it would run but then die again.
now what do you think is the problem here? did the carb get clogged when the fuel tank emptied???
do i need to put more gas in the tank?
i already checked the high tension wires and it is working fine.
