Results 1 to 5 of 5
Threaded View
    Jan 2009
    Sa lumang kotse namin (12+ years old na) we apply carb cleaner whenever we change oil.
    Simple lang naman. Remove air filter or open the tube which holds this. Spray into that tube (be careful carb cleaners can damage your car paint) after someone else turns the car on and revs high (press gas). Spray only when the rev is high otherwise the engine will die down. Hold high rev and spray from 10-15 seconds, 3-4 times. That's the first part. Effectively the sensors (MAF) have been cleaned by doing so. Turn the engine off.
    Now open where your throttle is. Nasa dulo ito ng tube na kaka spray mo lang. Remove tube and have someone open the throttle by pressing the gas. Spray into that opening. 2-3 times, 5-10 seconds. Close the throttle then return the tube. Close and return everything.
    After 15-20 minutes turn the engine on. You will notice the engine will rev very high. Normal yan. Press gently gas once in a while. After 5-10 minutes the rev would go down. Turn engine off and it will rev normally again.
    Doing this more often will not add any improvement to your car or engine performance. Every oil change lang pwede na. Flooded cars will benefit from this too.
    If you can locate your PCV (newer cars ata wala na nito. not sure). You may remove it and spray carb cleaner on both ends to clean it. Dry then return to the engine.
carb cleaner?
