john,
use the carburetor only as needed. your car might turnout to b e a carb cleaner addict. the neoprene seals and gaskets might get brittle. maybe once in six months. but if you use a clean air filter everytime this won't be necessary. many engines in the peelipins are dusted engines because they remove the air filter to tipid. refer to the jeepneys that need engine overhaul often because the ingested dust abraded the cylinder walls and the piston rings. gum and varnish comes from low quality fuel too. you get what you pay for. low quality fuels have less octane and more heptane and have less detergents in 'em.
jick
ang brand po pala ng nabili ko sa auto supply ay HARDEX carburator and choke cleaner po ang nakalagay......advise naman po TIA
