Results 1 to 10 of 10
BANNED BANNED BANNED
- Jul 2003
- 2,267
May 6th, 2008 09:26 AM #1
my wife's car is cvici esi 93. it has a 3 yr old problem. the problem is similar to fcuk_macky's (got the post from the other thread). nagagamit pa naman yung car but from turning on the engine the CEL light doesn't go off in 3 sec's as it should. it takes about 5 mins for the CEL light to turn off and that is the only time i can start the engine.
but if the car engine temp is up or the engine has been running for some time, the problem goes away.
btw, this problem cropped up when we changed the ignition coil and igniter some 3yrs ago also.
May 7th, 2008 05:00 AM #2
OEM ba yun igniter and coil? Surplus ba? If not then I suggest you get a new one from the casa or any reputable Honda parts dealer. If you still go for surplus a direct swap is a must to test the surplus unit.
- Jul 2003
- 2,267
May 7th, 2008 04:23 PM #3ignition coil is definitely replacement brand. magkano kaya orig honda nito???
igniter is surplus (brand new is quite expensive, casa quoted a price of 8K for this )
Tsikot Member Rank 5
- Nov 2003
- 3,849
May 22nd, 2008 09:07 AM #4see if there is an error code muna imo. it could be anything from the parts you replaced before to the main relay causing the problems.
- Jul 2003
- 2,267
May 20th, 2009 06:11 PM #5buhayin ko lang itong thread ko na ito.
habang nag-surf ako, napapunta ako sa isang site na nag-discuss about main relay of honda. then, nabasa ko some of the symptoms ay tulad nitong sa aming kotse na up to now ay ndi pa naayos hehehehe.
tinest ko yung main relay at mukang may problema nga. kaso wala sa local auto supply yung relay ng civic esi 93 ni misis.
any idea kung magkano ito sa surplus at kung ito kaya magiging solusyon sa problema ko?
THE AUTO SPECIALIST
- Mar 2006
- 607
May 20th, 2009 09:23 PM #6most common problem yung MAIN RELAY.
get the main relay exposed and turn the ignition ON
if the CEL stays on , tap the relay with a screw driver
and once the light turns off , try it again a few more times to confirm .
May 21st, 2009 03:27 AM #7
Katulad mo ang problema nito.....
TANONG:
My Honda Civic '95 will not start until the check engine light turns off. How do I fix this?
Battery was tested and is good. When the car is cold, the engine light takes longer to extinguish than after running for awhile. When the check engine light turns off I hear a click, and something sounds like is engaged, and the car starts with no complications. If I do not wait for the check engine light to turn off than the car will not turn over. What do I need to check or change to fix this problem?
SAGOT NG IBA:
1. Had a similar problem with a van, it ended up being the ecu . Found the problem by unhooking the ecu and bringing it inside at nite. Hooked it back up in the morning and it started right up. Took it out and left it in the fridge for 2 hours and the vehicle would not start with a cold ecu.
2. maybe the spark plug? Check the wires on the top of the intake manifold those might be gone. I think it might be something electric in the firing system. You should get it looked at.
3. If its efi then check for the relay next to the computer its for the fuel pump, one of the common faults in honda's.
- Jul 2003
- 2,267
May 21st, 2009 09:58 AM #8
May 21st, 2009 09:34 PM #9
fourtheboys
i had a first hand experience of the symptoms you described. i had a fix to this but i can not recall. it's been three years when a customer came in with that problem. this a recurring problem, you are not alone, what i will suggest is to cehck with the dealership service and ask for any technical service bulletins (TSB) or any recalls for your car. sometimes they are stingy with the information, you can log on to honda.com
jick
certified auto
guam
- Oct 2010
- 1
October 23rd, 2010 02:36 AM #10gnito gawin mo.palita mo ang main relay/ecu relay. ganyan din ang problema ng kotche ko nuon.honda civic 95 esi. main relay lng yan
Xiaomi E-Car
