Results 1 to 7 of 7
    May 2012
    Guys what is the possible cause ng pag shake ng kanina during Idle? But after the AC compressor kicks in the engine speed will climb a little (800RPM-900RPM) then when the AC compressor disengaged mag shake na naman sya.konti lang naman Pero medyo ramdam sa cabin since under the seats yung engine nya.thanks
    Feb 2009
    What vehicle, engine type and age of the car?
    Check your idling setting, it should be between 700 to 800 rpm. Also better check your engine supports, if they're busted or very old, they tend to be very stiff, failure to absorb or dampen the engine vibrations.
    if your car's idling is at around 700-800 at no aircon, it will vibrate... masyadong mababa..... ideal RPM with no ac should be at around 850.... pag naka AC around 900.
    Make and model please...
    Mar 2005
    Engine support and or transmission support
    Jan 2011
    just increase your idle speed and it will be fine. ok naman pala ang idle up mechanism.
Car Engine Shake a little when Idle?
