Guys what is the possible cause ng pag shake ng kanina during Idle? But after the AC compressor kicks in the engine speed will climb a little (800RPM-900RPM) then when the AC compressor disengaged mag shake na naman sya.konti lang naman Pero medyo ramdam sa cabin since under the seats yung engine nya.thanks
Check your idling setting, it should be between 700 to 800 rpm. Also better check your engine supports, if they're busted or very old, they tend to be very stiff, failure to absorb or dampen the engine vibrations.
if your car's idling is at around 700-800 at no aircon, it will vibrate... masyadong mababa..... ideal RPM with no ac should be at around 850.... pag naka AC around 900.
