Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
    Sep 2006
    That basement parking at Baguio Center Mall is not car friendly..bukod sa napakasteep ng driveway, paikot pa so it is difficult to make "buwelo"..it is very cramped, damp, and dark.
    Napansin ko nga yung wall dun damning gasgas..proof na marami ng nasagi na sasakyan doon.
    Yung papasok din sa parking dun sobrang steep..45 degrees also by my estimate.. so kung pabalik ka, most likely ganon din yung angle..paikot pa..
    Namatayan na rin ako ng makina doon nung gamit ko 1.6 na lynx.. mali lang talaga timpla ko. On the 2nd try, I really stepped on the gas hard para makausad ng mabuti..ayun...
    Nasaan fuel gauge mo, is it near empty when it happened?
    Dec 2007
    Quote Originally Posted by 4JGtootsie View Post
    Good thinking, sir! +100!
    Baka nabibitin sa fuel dahil pumupunta sa bandang likod ng tangke ang remaining gasoline. Kayang-kaya naman ng Avanza 1.3 ang mga ganyang akyatan. Lalo na't bago pa iyan.
    Aug 2004
    Actually, from a friend who uses a 1.3 Avanza to bring workers to Tagaytay, it really doesn't have much climbing power... but with just four passengers on a parking ramp, you should be able to get out if you do it right... Buwelo, keep your revs above 3000 rpm, and climb out. Tutal naman, very short yung first gear niya...
    2000 rpms ain't going to get you squat. The Avanza is a gasser, and gassers need revs for power. Now if you had an Innova diesel or another AUV, 2000-3000 rpms would be okay... but not on an Avanza!
    Agree ako, dapat handbrake ka rev hard then timing. Ako dati, may huminto sa gitna ng parking sa megamall ( mababa pa yun ah ) then ang dala ko is '96 corolla 1.3 lang. Ganun ginawa ko, kinaya naman. dapat more than 2000 rpm.
    Aug 2005
    Torque ng 1.3 avanza ay nasa almost 3K pataas. pag bumaba na ang rpm to 2,500 and falling habang paakyat, have to down shift para hindi mabitin sa power.
    Ang mga gas engines has low torque at 2,000 RPM. Diesels have a lot of torque at 2K RPM compared to gas.
    Tagaytay hilands ang pinaka matarik kong inakyat. 6 ang sakay with stuff pa. no problem.
    Nov 2007
    sir sana try mo 3k rpm mababa para sa akin din ang 2k rpm btw my mb100 & pregio lahat ng paakyat sa baguio ayos naman lalo na yung papunta kami sa rest house malapit sa marcos highway i think pinaka matarik na nadaanan ko na yun,, pangalawa is talisay batangas going up sa tagaytay sa parking mall naman dito ata sa ST FRANCIS SQUARE na basement ground
    paano ka nga pala naka akyat sir?
    Aug 2008
    Quote Originally Posted by rst619 View Post
    well since steep talaga ( sabi mo nga approx 45 deg ) i think kulang ka sa rev. 2000 rpm is too low in my opinion lang sir kaya hindi kayang i overcome ng makina ang grade.
    somebody pls correct me if i am wrong, pero kung sliding po ang clutch mo, mas hindi dapat mamatay ang makina: hindi ka gaano makakaabante, pero hindi dapat mamamatay.
    when standing still on a steep incline, engage handbreak, rev hard, then let the clutch up slowly. of course timing mo din pala pag release handbreak lol
    possible cause ang too low rpm... Yeah i should have tried this... Next time mapunta ulit ako dun, i will intentionaly stop sa middle ng ramp so i can try your suggestion...
    Quote Originally Posted by Picard View Post
    Sir the engine is 1.3L, rear wheel drive pa. Mahina talaga yan sa akyatan. 2K rpm really won't make it lalo na walang bwelo. Kung talagang hindi makakabwelo, I think best technique yung kay rst619...when standing still on a steep incline, engage handbreak, rev hard, then let the clutch up slowly. of course timing mo din pala pag release handbreak. Don't be afraid to rev hard when you need it...as long as wala sa redline it's safe.
    OK sir will try your suggestion next time na mapadpad ulit ako doon sa mall..
    agree talaga ako na matarik itong parking ramp dito sa Baguio center mall at makipot pa... kaya kung namali ka ng tantiya ay hagip mo ang wall.
    is this your first time to park there? siguro medyo alangan ka sa may kerb segment niya na paakyat kaya mahina lang tapak mo sa gas?always parking here but no problem... though mine is innova.
    No sir, madalas ako mag park dun... hindi naman ako alangan kasi makitid naman ang width ng avanza kaya madali lang i mani obra dun sa kurbada sa taas... the way i handled the situation i think is the problem medyo natipid ang pag rev and i forgot to engaged the handbrake he he he...
    Quote Originally Posted by Hanren View Post
    Yep! True! Ingat na lang po just in case you visit this mall here in baguio...
    3/4 pa po ang gas ko during that time...
    I see... Thanx for the info sir...
    Quote Originally Posted by aga_cruz View Post
    umatras po ako then nag bwelo..
    What i need nga siguro is more rev on the engine, kulang nga talaga siguro yung power ng engine... Will try to do your suggestions... Thnx sa mga ng reply... God Speed to all!
    dapat sinagad mo ang pagtapak sa gas or mataas na RPM. bitin talaga ang 2k RPM sa situation mo.
    Aug 2005
    Kung ang gas engine ng car ay 2.0 at 2,000 RPM, makakaakyat ba? same situation.
Car cannot climb steep road..
