Results 21 to 28 of 28
July 31st, 2007 11:04 AM #21
Yup. It's a balancing act. There's only so much power an engine will make safely.
For me, it's great to have the chip option, but I prefer for it to be custom mapped on the spot. Chips with set maps give wildly varying results on different cars.
Upgrade everything else first, then chip if you're not satisfied... ...breathing upgrades are the only "free" upgrades you have... ones that won't stress your engine more or give you other problems.
These include a new filter and intercooler fitting (there might be space for a Hilux-style top-mount on the Innova, from looking at the engine... but a front-mount is much superior) and mandrel bent down-pipes and exhaust. These should be sized and designed by someone reasonably familiar with the system... too much intercooler and you slow the intake too much...
It would be an interesting project... although one I'd like to see even more is a 3.0 D4D in the Innova...
- Jun 2007
- 207
August 1st, 2007 08:44 AM #22based on my experience sa makina after the upgrades mas lumakas un mkina and un fuel consumption nya gumanda tumipid,,as for the first part ng mods na intake and exhaust medyo the same pa rin un power..after installing the ecu upgrade mas pumino un andar and nwala un ingay ng mkina..mas tumipid sya k sa dati..
August 2nd, 2007 05:14 AM #23
- Oct 2006
- 69
August 3rd, 2007 06:47 PM #24
August 3rd, 2007 06:56 PM #25
gud day! mga sir sori po kung OT ako,,.ask ko lang po
if how many kilometer/liter does the V8 4.7 Landcruiser does??
tenkz n advance..,!
- Jun 2007
- 207
August 4th, 2007 08:04 AM #26aound 4-5 kilometers /liter ata un sir..pg hi way nsa 9-10 ata...based on my friends experience with his cruzer..
Tsikot Member Rank 3
- Aug 2004
- 2,452
August 4th, 2007 10:26 AM #27
- Jun 2007
- 207
August 4th, 2007 06:51 PM #28we havent tested it on a dyno pero the usual power gains for an ecu upgrade is from 20-30hp depending on the engine it was installed.. but yuo can feel the pwer after it was installed..we intstalled it in on a d4d 3.0L hilux..0-100 takes about 12 seconds.after installing it it was down to 10seconds..we tested it a couple of times and still it has almost the same responds 0-100 10sec and up..but never the same as before 0-100 12sec...btw theres no dyno shop here in davao..dyno butt lng..hehehe..kc yuo can really feel the seat of the pants respond after the install also un fuel consumption mas tumipid..
high idle RPM at engine start
