Results 11 to 16 of 16
- Oct 2009
- 8
November 6th, 2009 10:30 AM #11[SIZE=5]Wala naman ganun problem yong sasakyan sir katulad ng sayo. maganda din ang FC nya. yun lang talaga ang talsik lang ng oil sa oil cap ang napansin ko the rest is ok. nagtanong ako sa mechanic ok lang naman daw yon maganda nga daw ang engine pag ka ganun tumatalsik ang langis sa oil cap. pero yong sa kasama ko na naka galant vr4 hangin lang ang lumalabas sa oil cap nya as in hangin lang walang trace na langis whatsoever. normal ba eto sa mga rolla na old models sir? BTW, san nga pala nakalagay ang PCV system, sa labas o loob ng makina? .... TIA[/SIZE]
December 2nd, 2009 04:30 PM #12
for a gl corolla engine - this naturally spews oil because the scissor valves are near the cap. it differs form a 2e engine because of the location of the valves
December 2nd, 2009 04:36 PM #13
- Nov 2009
- 87
December 3rd, 2009 01:31 PM #14In any SERVITEK SERVICE CENTER I presume they can conduct compression test.
- Nov 2009
- 87
December 3rd, 2009 01:38 PM #15I agree. And another signs of loose compression if U're not a professional mechanic, the idling of the vehicle is ERATIC. Meaning, sometimes normal afterwards low or high. Next is the tail pipe of the vehicle, a white smoke is coming out. The ERATIC idling of the vehicle is very noticeable when U switch on the airconditioning unit of your vehicle. To the extent the engine will die down. Furthermore, use also vacuum tester. Said tester will also help U and confirm the condition of ur vehicle.
- Jun 2009
- 21
May 4th, 2012 09:53 PM #16for info lang po,hindi blow by ang tumatalsik na oil sa oil cap ng ae92.there is a worm gear located underneath that cap kaya natural na tatalsik oil kapag binuksan.hindi pro na mechanic yang nagsasabi ng ganyan.sa dip stick test pag me tumalsik na oil un ang blow by since gas engines are low compression engines.
-experienced toyota engine tuner,10 yrs-
high idle RPM at engine start
