Results 11 to 20 of 31
September 25th, 2011 07:27 AM #11
Sir dvldoc,
Maybe you can teach us how o properly clean the egr? I am sure my pick up truck has accumulated already atleast half of the dirt that is in the picture you posted since i da a lot of idling stop and go driving thru traffic here in downtown manila.....
September 25th, 2011 12:00 PM #13
Regular cleaning of the EGR will not harm it. You need a good degreasing solvent and some elbow grease to clean it out. Boiling water really breaks it up quickly as well. Just let it dry out before re-installing.
I recommend everyone inspect it at least once a year, every 6 months would be much better because they get nasty very quickly especially if you don't have a oil catch can.
September 25th, 2011 12:28 PM #14
i have a gen 3 pajero from japan, jdm unit... i completely cleaned the intake manifold and all intake tract including the egr throttle body etc... it was indeed dirty..
1. adding catch can can only reduce the dirt soo much... the catch can is not the major source of engine dirt but the EGR...
2. the Egr is a Necessary evil... if you maintain your EGr regularly there is no reason why you should close/remove it..
3. diesel engines produces more soot than petrol therefore cleaning must be more frequent... i think once a year would suffice..
the auto industry always aspire to lower emission and improve efficiency, the EGR was designed to lower emissions and improve efficiency, there are no immortal car parts! therefore all contraptions on our vehicles needs cleaning and replacing... if your EGR is dirty CLEAN IT.. if your EGR is faulty REPLACE IT,, but don't remove it. there is no guilt-free car.
On newer cars the EGR has a start up sensor, it will do a self test diagnosis by cycling the valve of the EGR to prevent it from stucking up, if its stucking up the EGR will send a fault code and engine light will illuminate..
on older cars there maybe no sensors in the EGR valve, therefore the owner must periodically listen to the thack-thack sound it produces during start up to know if its functioning... you can also manually use a multimeter to know if the circuitry is ok..
the owner is responsible for maintaining the vehicle in tip-top condition so that its emission and performance is good. Failure of a part is not a reason to completely removed it,, everything in your car has a valid function..
September 25th, 2011 01:09 PM #15
Unfortunately most people have no clue this is a issue. They only work if they are maintained.
September 26th, 2011 02:57 PM #16
as for my former shop foreman in the medium and heavy equipment shop if he can't figure it out:
alisin mo yan, pampagulo lang yan once he gets stuck on something. he refuses to learn just like many of our own people. stuck in the '70's car mentality. read, get educated and get training on things you feel is important or leave the vehicle maintenance to the professionals
September 26th, 2011 03:12 PM #17
September 26th, 2011 08:47 PM #18
where is the egr in the xuv 05 A/T turbo? i will try to clean it DIY. it would better if somebody can post pics where it is. TIA.
September 27th, 2011 06:54 AM #19
there are bolts and gaskets to remove... i first remove the engine top cover(plastic at top of engine).. then remove the airfilter box. remove the throttle body assembly. remove the sparkplug covers. remove the electrical sensors at the top of the intake manifold. and then remove the manifold itself... the engine was really dirty lots of gunk... once i was able to clean it,, fuel consumption improved and it feels light to drive (considering na gasoline engine pa yun ha)....
that is true we should remove the lame mechanic mentality... we should read and educate ourselves. in the end tayo din nakikinabang dahil meh alam ka sa car mo and basic engine hindi ka agad maloloko ng mechanic and you'll be more confident dealing with shops.
- Apr 2010
- 91
September 27th, 2011 01:45 PM #20
Xiaomi E-Car
