Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
    #21
    sir,
    maybe if i take a picture of the 3.2liter engine, maybe the experts can mark the parts so i can know the parts to clean and takeout.
    Jan 2008
    #22
    magandang pamalit dyan sa EGR eh yung water alcohol injection.. ang talagang purpose ng EGR is too prevent the formation of NOX by introducing exhaust gas.. since carbon monoxide yan mababawasan yung oxygen content nung hangin na papasok sa intake manifold there by preventing NOX since NOX is a by product of high combustion temperature and too much oxygen... kaya nga madalas ang mga makina na may EGR ay yung naka TURBO kasi yung turbo nagbibigay ng excess oxygen sa intake manifold and to control that is the EGR.. ngayon sa water alcohol injection yung combustion temp ang mag lolower thus preventing NOx..
    gusto ko sana ng water alcohol injection kaya lang mahal pa mag pakabit ng kit eh.. nasa 10k up pa ata
    Dec 2007
    #23
    Yes with water injection you will basically never have to clean out your EGR valve, not to mention it will significantly lower your NOX emissions. Even if your remove the EGR valve you will still have lower emissions than you would have with it in place with the water injection in use.
    May 2009
    #24
    lucky me no egr valve in my truck. just an oil catch tank fabricated from a spent A/C drier-filter...
    Jul 2011
    #25
    Regular cleaning of the EGR will not harm it. You need a good degreasing solvent and some elbow grease to clean it out. Boiling water really breaks it up quickly as well. Just let it dry out before re-installing.
    I recommend everyone inspect it at least once a year, every 6 months would be much better because they get nasty very quickly especially if you don't have a oil catch can.
    sir dun sa service manual ng jazz ko, may nakikita akong EGR valve at pipe. parehas ba sila dapat linisin? pag sa casa nagpa-PMS, nililinis din ba nila ito at certain intervals?
    Quote Originally Posted by s10pao View Post
    Sa gas engine not much problem IMO pero dapat linisin pa rin.
    #27
    i felt guilty after reading this thread, my EGR was blocked around a year ago to solve the black smoke problem on my 4M40. we cleaned the EGR today. it was full of gunk. it was stuck open(?) that's why the engine was smokey. however, didnt have the chance to clean the intake manifold anymore.
    Jan 2003
    #28
    Quote Originally Posted by miked View Post
    I am planning on doing this too, can you share a picture of what you have?
    #29
    up for this. my starex Grx Crdi has been belching smoke, under-powered and fuel consumption is very bad. Hyundai Casa said the EGR needs replacement.. im afraid it might cost me an arm and leg.. will removing the EGR for this particular model work? (Starex GRX CRDi)
    Quote Originally Posted by poorprince View Post
    No, just clean it first baka puwede pa. CRDi kasi yan, nasa ECU niyan na dapat gumagana EGR mo. Check engine labas niyan if tatanggalin or i-block mo.
    #31
    thanks sir.. im having it cleaned first and have the injectors cleaned/calibrated.
Blocking of egr
