Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Oct 2008
    tanong po. me 2007 1.3L na Avanza.
    usual city driving lang po.
    nong last week, nag punta kmi meycauayan, parang ok naman takbo kahit mga 90kph.
    nitong weekend, pumunta kami pansol calamba. napansin ko pag mag 80kph na takbo ko parang kinakapos. tapos pag paakyat, dapat mga 60kph lang tabko ko.
    ano kaya problem? kakatapos lang ng 70km PMS ko sa toyota (abt 3 weeks ago) and wala naman sila nakita. bago palit ang plugs pero yong air filter di pa pinalitan.
    help naman po
    Jun 2005
    Ilan sakay mo nung una at nung huli na byahe? Malaking bagay ang dami/bigat sa acceleration.
    Pwede mo palitan air filter mo kung yun lang di napalitan
    Quote Originally Posted by african888 View Post
    help naman po
    Nag PMS ang unit mo, pero di pinalitan ang Air Filter. Try running your vehicle temporarily without that old Air Filter. And observe, if it improves your accelaration and speed. Kung hindi, install it back the filter. Nagpalit kamo ikaw ng new set ng spark plug. Nag set ba sila ng timing? Kung hindi, ipa-timing mo. Naka tono kasi ang timing sa dati mo sparkplug, malamang hindi pa sa bago sparkplug. Just my opinion.
    Sent from my UP+ using Tapatalk
    help naman po
    Nagpa 70km PMS ka na. Usually sa ganyan odometer readings, palit or change transmission oil na rin.
    Jul 2011
    help naman po
    MT ba ito sir? if it is, pakiramdaman mo, pwedeng nagsisimula ng dumudulas ang clutch.
    if AT, paflush mo ATF, then fill in fresh batch.
    Quote Originally Posted by rodetor View Post
    distributor-less engines doesn't need to be manually adjusted, wala ka ng gagalawing distrubutor for the timing.
    the ecu will automatically adjust by itself.
    the least TS can do is, reset the ecu.
    Feb 2005
    Quote Originally Posted by 7138 View Post
    can you please elaborate, kung walang distributor, san kukuha ng spark mga sparkplugs? o mali lang intindi ko?
    Oct 2009
    Quote Originally Posted by box_type View Post
    yan ung mga latest model na wala kana nakikitang mga hightension wire na papuntang distributor at spark plug.na pinipihit kapag tinutukan ng timing gun.
    Almost 10yrs hehehe nice. Napalitan na ang fuel filter?
    When its a power issue it is normally air or fuel or the ignition.
    Another possibility is the throttle body. It probably needs cleaning. 350 pesos in some shops. Pwede rin pa check ang ecu also.
    Jul 2006
    City driving most of the time?
    Carbon build-up lang. Italian tune-up kailangan.
    Drive it like you stole it.
    Jul 2011
    those engines that are already using coil packs, yun na yung pinaka ignition coil nya,
    per spark plug na agad, wala ng tatakbuhing high tension wire,
    ecu na ang gumagawa ng distribution as to which spark plug will fire.
Parang kinakapos pag more than 80kph ang speed at paakyat
