Page 1 of 5 12345 LastLast
Results 1 to 10 of 42
    Jun 2009
    Guys, what are the brands of oil filters and type, brand of oil would you recommend for a 2001 2.0L REVO GSX? use for normal driving, and budget conscious.
    best is to follow the recommended oil viscosity based on the manual. then you can choose to DIY or bring it to any gas stations.
    for filter replacement, Vic or Bosch is commonly used though i prefer Bosch
    Nov 2007
    not sure kung maraming autoshop na nagtitinda ng bosch filters but yung VIC filters ang madaling hanapin.
    xto, san ka nakakabili ng bosch filters?
    Oct 2007
    Quote Originally Posted by Esnie.com View Post
    sir, try mo sa:
    [SIZE=3]Grand Luxor - #14 Kabignayan St., Banawe, Quezon City. Contact number nila .. 7120071 [/SIZE]- distributor/retailer po sila ng BOSCH
    Warren Auto Supply
    Benavidez St. near CM Recto, Binondo Mla.
    tel 244-1775
    authorized dealer sila ng Bosch (filters, brake pads, bulbs, horn and battery) and Osram.
    http://rb-aa.bosch.com/boaa-ph/Categ...&publication=1
    double post
    Apr 2008
    royal purple medyo pricey nga lang kasi 500 pesos kada isang litro nito eh
    magnatec ang isang gallon nasa 800 pesos hanggang 1k
    ok din naman ang ibang castrol delo, helix, rimula, rotela, valvoline, enoc, mobil at iba pa
    wag lang REV-X kasi marami nang nabiktima nito tinatawag itong traydor na langis dahil marami na kasi pinakatok na makina nitong langis na'to
    sa filter naman ok ang vic basta lagi lang regular ang change oil mo ayon sa kung ilang kilometers para mag change oil ka kung gusto mo naman mahaba-haba dun ka sa bosch.
    Royal Purple would be nice, (1 year na sa altis ko)
    filters? OEM would be the best. just buy it outside the casa.
    if regular naman ang oil change mo, kahit hindi synthetic oil pwede na. . .ako i do it every 5,000 km or 5 mos; whichever comes first
    always been a combination of castrol and vic for me
    bosch oil filters can be bought in any servitek shops. dyan ako bumibili eh.
    for oils, any recommended mineral oil with the same recommended viscosity for your vehicle would be ok. just have it regularly changed every 5k kms. it will be cheaper than having to fill up with fully synthetic oil tapos once a year mo papalitan, and you can be assured that you always have fresh oil inside your vehicle.
    for oil filters, VIC is also good.
Good Oil Filter and Oil
