Page 4 of 11 FirstFirst 12345678 ... LastLast
Results 31 to 40 of 102
    #31
    Quote Originally Posted by JapanABC View Post
    Ingat lng bro, ang Purolator na binebenta dito satin ay made in China, cheapest version of Purolator same as the Bosch filter yung yellow package which is outsourced from an independent factory in Vietnam cheapest version din.
    Mga sir how about yung MOTUL specific CRDI 5w 4p pwede ba sa mux natin? Plan ko rin kasi sa labas na lang magpa service ng 20k km. At kailangan ba talaga palitan lahat ng fluids like ATF, COOLANT, GEAR OIL and BRAKE FLUID? Thanks guys.
    Jan 2008
    #32
    Quote Originally Posted by LuckyMan View Post
    actually every 40k palit all fluids. but then may mga fluids na pedeng gamitin na pedeng mas matagal change interval
    May 2017
    #33
    Quote Originally Posted by Wh1stl3r2 View Post
    30 weight seems too thin for diesels in our climate. Also remember these are modern diesels with multiple fuel injections per cylinder per cycle. Fuel dilution could be a factor earlier in the life of the oil. By the time you change your oil your 30 weight might have sheared to a 20 weight oil. Not so sure that's safe for a diesel. No doubt 30 weight will give you better fuel economy and maybe all around performance, but you might have to change your oil much earlier than if a 40 weight oil were used.
    Mux/Dmax new.models and old all need 15w-40 oil in Philippines climate. In Australia all Isuzu owners use 15w-40. Caltex Delo multigrade seams to be one of the best on the market if you changing oil every 5k. If over 5k use a fully synthetic.
    Australians have clocked up over 200k on theur unuts using a 15w-40 weight oil and no issues at all button line is clean oil. And nothing wrong with Vic oil fingers provided you only do 5k oil changes on them
    May 2017
    #34
    I agree with you.
    Jan 2008
    #35
    Iba nga lang un performance ng 5w40 sa 15w40, sa fuel consumption pa lang mas matipid un 5w40.
    Delo gold ang observation nun isang 1 tropa ay mejo mausok na after 1k km. Better use delo400 kung 15w40, kahit gang 10k km, di nagbabago performance
    Sent from my R7plusf using Tapatalk
    Jan 2018
    #36
    I use Motul H-tech 100 Fully synthetic 10w40 in both our diesel cars, yun din recommend ng shop that I always frequent to (that shop also service Porsches 911s, Stis, Evos, so I somehow trust them LOL). I'm pretty sure yun ang mostly nilalagay nila to Diesel cars that they service. 550 per liter, good for 10k kms.
    Jan 2008
    #37
    Ako delo lang ang pinagkakatiwalaan ko na diesel oil. Kasi yan proven na sa bus at truck. Di ako bilib kung gagamitin sa porsche o bmw, etc, kasi usually weekend car lang naman mga yan, minsan hindi pa ginagamit kahit weekends lalo na kung umuulan. Di talaga kayang sirain.
    Under normal use di basta basta masisira ang oto. Sa taxi, jeep, bus, truck ang sukatan talaga.
    Pero maganda talaga din ang motul, ginagamit sa race
    May 2016
    #38
    Quote Originally Posted by kkreuk18 View Post
    Ano anong delo oil na po nagamit niyo? And ano pinaka ok para sayo?
    Im using delo gold 15w40..
    Balak ko na mag fully syn next oil change
    #39
    ^ try mo delo 400 mgx. It's supposedly the best in the budget delo line-up. Although hindi sya fully synth variant.
    I personally Just bought 7 liters of them to use on my next oil change. Will pair them w/ a baldwin double filtration oil filter.
    #40
    Quote Originally Posted by Grimm View Post
    bro isuzu didnt mention fs or mineral. follow recommended 10w30 and correct api rating..
    on thicker oil..
    Pat's Perspectives - Thicker Oil (#2) - YouTube
Best Diesel Engine Oil and Replacement Oil Filter for Isuzu MU-x?
