Results 11 to 14 of 14
Tsikot Member Rank 5
- Nov 2003
- 3,849
May 9th, 2006 11:26 PM #11iqaruzz, the reasons you stated for the percieved increase of displacement of the rotary engine is wrong. it's not because the engine has 2 rotors (which it does), but rather because it normally requires 2 rotations of the rotor for it to be considered as one combustion stroke.
so normally it's about 600+cc per rotor x 2 rotors x 2 rotations
or in the cosmo 3 rotor engine it is 3 rotors x 2 rotations.
you come up with close to the approx equivalent piston engined displacement but use the wrong formula.
May 17th, 2006 09:14 AM #12Originally Posted by speedyfix
Formula I've given actually lacks of details. ("brief summary to cc ratings")
What I understand about this is, each face of the rotor is 650 cc and there are three face, two rotor. It takes 3 eccentric shaft rotation cycle to complete one engine cycle. Weird in a way its like a 3 stroke engine.
So in one engine cycle it actually did 3.9 Litres.
Hmmm, if you have a total of 2 rotations of the eccentric shaft in comparison to 2 rotations of the crankshaft in 4-stroker. The 13B would be actually 2.6 litres.
Reason I did this way is I have previously explained it to few people who hasnt worked/seen rotary engine. And actually took me few hours trying to explain it. My bad!
- Nov 2003
- 3,849
May 17th, 2006 10:55 AM #13don't worry about it you should always bring a diagram of the engine para maexplain mo sa di pa nakakakita. hehe!
- Sep 2006
- 8
March 14th, 2007 05:27 PM #14You are totally off here. For RX-8 Renesis engine, it is recommended that you use mineral based engine oil, not fully synthetic. I am currently using Quakerstate 5W-30 (found it at True Value). As for the interval, I am planning to change it every 5,000 kms. As for any mechanics in the Philippines, I am still looking for one.
Regards.
In my car idle on coldstart was 2k high need 2 to3 mins to be restarted the engine to get the...
high idle RPM at engine start
