Page 1 of 3 123 LastLast
Results 1 to 20 of 42
    Aug 2020
    I had an experienced with js asakashi c-0076 installed on my mux 2017 2.5 mt 4jk1-tc. The anti drain back valve (ADBV) did not work, the oil in the filter will go back to the sump after resting for 8 hours. The oil filter is horizontally installed in the engine. For your info mga bossing.
    Quote Originally Posted by waldnerdoe View Post
    have you been using this particular brand/model for long?
    san nyo po nabili?
    is it possible, you are using a fake item?
    san nyo po nabili?
    worry ko baka OK naman yung brand, pero rep nung kalaban na brand
    https://www.tsikot.com/forums/search...rchid=10948411
    Jan 2009
    Would be interesting to know how you came up to that conclusion.
    eto yun testing na ginawa bro
    Good Oil Filter and Oil
    Jan 2009
    As with anything, some works better than others.
    IMO.... again, my opinion. I think the ADBV works best with the filter mounted vertically or near-vertical, with the thread at the bottom. Gravity will pull the oil down and force the ADBV closed. With the filter mounted horizontally, there's less force applied in closing the ADBV, so expect some oil to seep back out the inlet holes.
    Also, oil permeates through the filter media and if you remove the filter, oil will leak out the outlet port. That's normal.
    And last thing, the oil typically flows as such....
    Sump > pump > filter > oil galleries > moving parts > sump
    When you turn off the engine, oil left in the galleries, moving parts, and most internal engine surfaces, flows back to the sump. That's the reason you get a higher dipstick reading when the engine has not been running for a while. The "extra" oil did not all come from the oil filter.
    bro ibig sabihin nagkamali assessment si waldnerdoe?
    medyo naparanoid din kasi ako sa post nya kasi last year gumamit din ako nung brand na yun for my vios
    i am wondering,
    if the oil filter draining issue is a significant one,
    why don't car manufacturers design engines with oil filters mounted vertically, with the thread up?
    that should solve dry-filter syndrome.
    Jan 2009
    I have no experience with that oil filter.
    Anyway, ganito lang yan.... oil filters are relatively cheap. If you're not confident with one brand/model, you can try a different one and see if it works better for you. But you should adhere to two things: The oil filter must be from a reputable brand...not to mention, genuine. 2nd, it should be designed or compatible to your vehicle.
    Personally, I'm satisfied with Wix for my 2.5 Innova Diesel. They're a reputable brand and many reviewers online who have cut them open gave it good grades. Though, I must admit that haven't gone through the actual testing myself but then again, if these oil filters were anything but good, we would've heard something about them causing engine failures. But I have seen none of those so far.
    thanks bro!
    wix na yun na order ko from bro crazy_boy good for 1 year (3 pcs) hehehe
    if di ako nakakakuha ng filter from bro cb, OEM binibili ko from casa para sure din
    Aug 2020
    I used vic oil filter before and i check the dipstick it is within the maximum level while in the asakashi it goes beyong the maximum. I also test the js asakashi filter by putting oil on it the have it positioned horizontally and the oil comes out the adbv. While in my old isuzu filter the oil doesn't come out. This is just for your reference with regards said brand. I haven't tested the vic filter coz it was immediately thrown away.
    Aug 2020
    I purchased the filter in lazada under f2 auto parts
    Jan 2009
    i am wondering,
    Good question. There are a lot vehicles that employs that design. Most Hondas do that.
    But if I were to take a stab at as to why not all engines are like that, I guess it all comes down to engineering, design and cost, among others.
    When manufacturing at scale, component placement and orientation has a price tag attached to it. It's not uncommon for the bean counters during an engine's R&D to veto the engineers' wishes and put this and that part a certain way so it will cost less to make. So, it's not hard to imagine that they'd sooner orient an oil filter upside down or sideways because doing it the right way will require a bit more plumbing (read: expense). Whereas using a filter with just a little ol' silicone ADBV would cost much, much less.
    ah yess...
    there was this manufacturer that vetoed putting front stabilizers on its car.
    as a result, "the car wallowed like a pig when cornering", which, they felt, contributed to poor sales.
    they attempted to remedy it, but by then, the car was dead in the sales charts because of other issues.
    OT.
    basta ako baldwin the best I have brand loyalty basta na impress ako sa product so Amaron for batteries and Baldwin for oil filters hehe
    i guess the question of the layman is,
    "how do i know the oil is a good oil?"
    Dec 2013
    There is a possibility thay you may have encountered a defective filter if that's the case. Since one of the official distributors of VIC filters is already carrying JS Asakashi filters as well. So I doubt that one defective filter damages the whole brand besides JS Asakashi filter is also sold in Australia, Russia, Singapore, Malaysia, Sri Lanka, Brunei and etc... if they are a bad quality filter then other countries will not buy their product. If one the offical VIC filter distributor is shifting on selling JS Asakashi filters then that signals something about VIC filters. Do you have any proof of testing about what your saying is true? It's hard to believe in just hearsays of a new member without testing evidences, proper facts and examinations. Do you have any proof of testing about what your saying is true? It's hard to believe in just hearsays of a new member without testing evidences, proper facts and examinations.
    There is a video online showing a testing of Dai-wa, VIC and JS Asakashi oil filters.
    Dai-wa, VIC & JS Asakashi oil filter pressure test 2020 - YouTube
    Dec 2013
    By the way guys I found videos of air filters on Youtube, they tested the filtration capabilities of K&N, BMG, WIX, Purolator and etc... and the myths of K&N, BMG and other washable filters have been finally debunked. Here are the testing videos about O.E. vs. washable performance filters.
    The tests shows that bigger micron flour, sand and iron dusts can pass through more on the washable performance filters with the oil applied on them than standard O.E. type filters. What more for the smaller sized particles like fine particles from electric powerplants, factories, cement dusts, brake dusts and etc... it will wear the engine faster than its normal life.
    1st video by Project Farm
    Which Car Air Filter is Best? Let's find out! Fram, K&N, Wix, Purolator, & AC Delco showdown - YouTube
    2nd video by bhvrdr
    Do performance air filters like BMC, K&N, Sprint let more sand and dust than OEM and is it worth it? - YouTube
    Dec 2013
    I'm also curious on what kind of measures did you determine that the oil filter ADBV is leaking, did you hold it horizontally, vertically & etc...?
    Aug 2020
    Quote Originally Posted by JapanABC View Post
    Watch this oil filter anti drain back valve - YouTube oil filter anti drain back valve - YouTube
Bad oil filters
