Results 1 to 10 of 17
- Jul 2004
- 22
March 19th, 2008 12:56 PM #1ano po kaya problema nitong car ko ( 1996 mazda 323 sedan).
last week while driving home, from imus cavite.
biglang naramdam ko na parang nanginig yung sasakyan nung tapakan ko yung gas namatay nalang siya and yung battery indicator nag-on.
after mga 30min start ko ulit yung car tumakbo naman for about mga 2 kilometers and balik ulit yung problema, since nag-on yung battery indicator i decided na palitan ko yung battery but still the same problem occurs.
pati alternator chineck din okay naman.
ano kaya problema nito?
thanks
March 19th, 2008 01:25 PM #2
marami bang load yung sasakyan mo? baka di na kaya ng alternator o hindi nagchacharge yung baterya.. try mo din check yung spark plugs mo kasi sabi mo nanginginig yung engine..
- Jul 2004
- 22
March 19th, 2008 01:45 PM #3wala naman siyang extra load, no sound set-up etc.
a/t pala siya, anyway sige try ko rin i-check yung spark plug.
thanks.
March 19th, 2008 02:04 PM #4
March 19th, 2008 02:22 PM #5
your problem has nothing to do with the battery or the alternator. normal lang na mag-light up ang battery indicator pag namatay ang makina.
i tend to agree with wohoo, baka sa fuel yan. it could be gas tank is empty, or water in the fuel filter, or damaged fuel pump.
March 19th, 2008 02:33 PM #6
kung may ignition coil yan sir. hawakan mo pag namatay. pag mainit na mainit baka yan ang sira.
March 19th, 2008 02:38 PM #7
ignition coil, spark plug, or tension wire, check mo rin fuel lines mo at fuel filter.IMO
March 19th, 2008 02:42 PM #8
walang konek sa battery yan ..
baka nga may water sa fuel lines or super clogged up filter ..
try to clean or replace the spark plug ..
March 19th, 2008 02:52 PM #9
sir, check your fuel lines, fuel filter/strainer(replace na lang para sigurado), have your fuel tank cleaned.... ususally fuel related lang mga ganyan.... pero if not check your high ten wires and spark plugs
- Jul 2004
- 22
March 19th, 2008 02:57 PM #10mga sir,
maraming salamt sa inyong lahat.
this week end siguro gawin ko to.
thanks again.
Suzuki JIMNY [merged threads]
