Results 11 to 17 of 17
- Jan 2008
- 4,726
March 19th, 2008 05:22 PM #11
possible nga na umiinit ang ignition coil mo possible na mamatay talaga ang engine since bumababa yung electrical current supplied to your engines' spark plugs...kung carburetor engine mo madali lang palitan yan pero kung yun DOHC ng mazda eh built-in sa distributor yung ignition coil, buong assembly papalitan, you can buy brandnew or surplus...
also possible is your fuel pump, modern cars use electronic fuel pump (it looks like the water pump used in aquariums but more rigid), yung ibang cars have mechanical fuel pumps installed sa engine mismo.. but yung mga electronic nsa loob ng fuel tank yung pump.. so be carefull during replacement lalo na pag drained na fuel tank more prone to explosion...
same problem i experienced with a nissan vanette carburetor engine.. una ko pinalitan yung ignition coil but still ganun pa din problem.. minsan mag start sya ok naman takbo tapos biglang mamatay.. then check ko din fuel system ok naman until check ko yung fuel pump, intermittent na pala namamatay yung pump kaya kinakapos ng fuel.. nung pagpalit ko ok na ulit.. fuel pump for nissan cost me around 3k...
March 19th, 2008 05:53 PM #12
Tulad din ng sinabi ng ibang members; mukhang "ignition coil" nga ang problema dahil umandar sya uli after 30 min. Yan ang sakit ng ignition coil kapag defective na at after palamigin mo ay aandar uli.
If it happens again, lagyan mo lang ng "wet" na basahan para lumamig.
Tsikot Member Rank 5
- Nov 2003
- 3,849
March 24th, 2008 08:40 AM #14coil, fuel pump etc. you will have to do checks so you can pinpoint the problem and not just replace parts without knowing kung sira or not.
- Jul 2004
- 22
March 24th, 2008 04:08 PM #15sir speedy,
how would i know kung sira na yung fuel pump?
sa ngayon yung fuel tank pinababa ko na kasi sabi nung mekaniko mukhang sira daw yung fuel pump.
thanks.
- 28
April 1st, 2008 05:01 PM #16Hi. I also had a Mazda before and had the same problem. I had the gas tank pulled out and had it cleaned. May mga nakitang mga putik and silicone inside the tank. Dont know where the silicone strips came from but cleaning the tank solved the problem. Change the fuel filter na rin. Hope this helps
- Nov 2003
- 3,849
April 3rd, 2008 09:15 PM #17irekta yung pump to a power source and see if it pumps. if it doesn't then sira na sya.
Xiaomi E-Car
