Results 1 to 17 of 17
    Jul 2004
    ano po kaya problema nitong car ko ( 1996 mazda 323 sedan).
    last week while driving home, from imus cavite.
    biglang naramdam ko na parang nanginig yung sasakyan nung tapakan ko yung gas namatay nalang siya and yung battery indicator nag-on.
    after mga 30min start ko ulit yung car tumakbo naman for about mga 2 kilometers and balik ulit yung problema, since nag-on yung battery indicator i decided na palitan ko yung battery but still the same problem occurs.
    pati alternator chineck din okay naman.
    ano kaya problema nito?
    thanks
    Aug 2007
    marami bang load yung sasakyan mo? baka di na kaya ng alternator o hindi nagchacharge yung baterya.. try mo din check yung spark plugs mo kasi sabi mo nanginginig yung engine..
    Jul 2004
    wala naman siyang extra load, no sound set-up etc.
    a/t pala siya, anyway sige try ko rin i-check yung spark plug.
    thanks.
    Dec 2007
    Quote Originally Posted by paopao View Post
    thanks.
    A shot in the dark... Baka sira ang fuel gauge, at sayad na ang gasolina?
    your problem has nothing to do with the battery or the alternator. normal lang na mag-light up ang battery indicator pag namatay ang makina.
    i tend to agree with wohoo, baka sa fuel yan. it could be gas tank is empty, or water in the fuel filter, or damaged fuel pump.
    Jul 2006
    kung may ignition coil yan sir. hawakan mo pag namatay. pag mainit na mainit baka yan ang sira.
    Jan 2008
    thanks
    possible nga na umiinit ang ignition coil mo possible na mamatay talaga ang engine since bumababa yung electrical current supplied to your engines' spark plugs...kung carburetor engine mo madali lang palitan yan pero kung yun DOHC ng mazda eh built-in sa distributor yung ignition coil, buong assembly papalitan, you can buy brandnew or surplus...
    also possible is your fuel pump, modern cars use electronic fuel pump (it looks like the water pump used in aquariums but more rigid), yung ibang cars have mechanical fuel pumps installed sa engine mismo.. but yung mga electronic nsa loob ng fuel tank yung pump.. so be carefull during replacement lalo na pag drained na fuel tank more prone to explosion...
    same problem i experienced with a nissan vanette carburetor engine.. una ko pinalitan yung ignition coil but still ganun pa din problem.. minsan mag start sya ok naman takbo tapos biglang mamatay.. then check ko din fuel system ok naman until check ko yung fuel pump, intermittent na pala namamatay yung pump kaya kinakapos ng fuel.. nung pagpalit ko ok na ulit.. fuel pump for nissan cost me around 3k...
    Jul 2004
    Tulad din ng sinabi ng ibang members; mukhang "ignition coil" nga ang problema dahil umandar sya uli after 30 min. Yan ang sakit ng ignition coil kapag defective na at after palamigin mo ay aandar uli.
    If it happens again, lagyan mo lang ng "wet" na basahan para lumamig.
    Oct 2007
    Try to check your ignition coil.
    Nov 2003
    coil, fuel pump etc. you will have to do checks so you can pinpoint the problem and not just replace parts without knowing kung sira or not.
    Jul 2004
    sir speedy,
    how would i know kung sira na yung fuel pump?
    sa ngayon yung fuel tank pinababa ko na kasi sabi nung mekaniko mukhang sira daw yung fuel pump.
    thanks.
ano kaya problema ng car ko?
