Results 1 to 10 of 102
- Dec 2007
- 4
April 25th, 2008 04:00 PM #1hi..i just wanna ask if i can use a shell helix ultra 5w40 in my ford explorer sport trac? thanks...
April 25th, 2008 08:49 PM #2
ano po yung engine?
may sticker po dyan sa engine with oil grade ranges and oil classification. ex: 5w30, API/ACEA: SG
April 26th, 2008 12:07 AM #3
Alternatively you can check your owner's manual. Malamang may nakalagay doon.
Most engines don't have a problem with 5W-40 viscosity oil though.
- Dec 2007
- 4
April 26th, 2008 07:40 AM #4it has a v6 4.0liter..210hp the manual says its uses a 5w30 oil...if i put a 5w40 oil what will does it do my engine?thank's
April 26th, 2008 07:48 AM #5
Mas malapot yung 5W-40 oil kapag mainit.
"5W-40" is a viscosity rating. The higher the number, the thicker the oil. The "W" means "Winter" so that's the viscosity of the oil when the engine is cold; the other number is the oil's "hot" viscosity.
More viscous oil gives your engine more protection, but at the expense of some fuel economy. Conversely, less viscous oil gives less protection but helps fuel economy.
Maghanap ka na lang ng 5W-30 oil, I imagine your big V6 might guzzle marginally more fuel if you did use 5W-40 oil. Technically there should be no other problems in using it though.
April 26th, 2008 07:59 AM #6
diesel po ba or gas ang engine ng sportrac nyo?
meron kasi din ata 5W-40 grade for both gas and diesel type engines
Tsikot Member Rank 4
- Jun 2006
- 2,605
April 26th, 2008 09:31 AM #7The 5w40 is ok. It wont harm your engine. Although, when I used Shell's 5w40 on my dad'd BMW, it lost about a litter after around 4000 kms. No leaks and less than 20,000 kms on the odometer. Another tsikoteer, ( I think it's Niky) also had a similar experience with this oil.
If you can, use 5w30 or 10w30 energy conserving oil on your next oil change. I recommend Royal Purple. It gave me better FC compared to Caltex Havoline Energy.
April 26th, 2008 09:36 AM #8
sirs, balak ko mag DIY ng change oil. ok lang ba na i-drain ko yung oil sa gabi then iwan kong bukas yung pan. then sa umaga ko lagyan ng bagong oil and oil filter?
April 26th, 2008 09:55 AM #9
April 26th, 2008 10:00 AM #10
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
