Results 11 to 12 of 12
October 14th, 2009 11:47 AM #11
no leaks sa water side? try running your engine while your rad cap is open. observe for bubbles... if there is presence of bubbles you have a leak in your cylinder head gasket which causes the water to overflow when your engine is runnning. water escapes the overflow provision in your coolant reservoir... not saying this is it but it's worth looking at.
- Oct 2009
- 10
October 20th, 2009 07:55 PM #12try nyo check you mga tubings. baka medyo maluwag na at medyo nag li leak na yung coolant mo while the engine is running. this has actually happened to me. what i did is i put teflon on all ends of the tubings to tighten it. ayun ok na.
