Other than having a turbo and intercooler kit. What other mods would you do to your ride to increase/maximize performance and interior/exterior looks? : )
Without any of those turbo upgrade....I would suggest a free-flowing air-filter like k&n.... a CAI set-up or a snorkel set-up para mas malakas at mas malamig hangin sa engine.
On diesel-fed engines, you can have the cylinder head machined. Intake/exhaust port and polished, stress relieved, over-sized pistons, flywheel skimmed to match you clutch disc. Ceramic coating may also help contain the heat inside the combustion chamber since diesel engines use heat to burn its fuel.
Ungas, kapag pina machine yung cylinder tapos gumamit ng oversized pistons, di ba magincrease ang displacement ng engine? yung 4.2li ng safari baka maging 4.25li ? :roll:
boybi::: Ang tanong kung may parts na available pang-oversize. What I mean is, kung meron man oversized pistons minsan wala naman piston rings. Yes, tataas din ng konti ang displacement.
ARB::: Dipende sa cylinder head, kung overhead cam ang engine, there is a possibility na tumaas ng bahagya but not easily noticeable. Cam lobes can be adjusted. valve seats machined into three to five angle for smoother intake and exhaust. Dome type combustion ceiling. Maraming pwede gawin. But ofcourse, there is the factor that the machined parts will depend on how sturdy the metal is.
marami akong hindi maintindihan...
Any particular modification i should do for my ride para mas malakas tumakbo, more quiet engine, better fuel efficiency... Sobra na ba ako mangarap? Hehehe
btw, my ride is xuv at.
Hmmm... mukhang mahirap yata yang plano. Malakas tumakbo, panigurado malakas din sa konsumo. Kahit na may intercooler turbo pa available para sa makina, dagdag sa konsumo ang extra power na kailangan.
Originally posted by Ungas Hmmm... mukhang mahirap yata yang plano. Malakas tumakbo, panigurado malakas din sa konsumo. Kahit na may intercooler turbo pa available para sa makina, dagdag sa konsumo ang extra power na kailangan.
