Results 11 to 16 of 16
August 25th, 2007 06:59 PM #11
* Niky
Ey, ask ko lang po, is there any shop who replicates the "Cone air filter Adaptor" that you've posted from simota? Kase i have this plastic elbow adaptor that was attached dun sa filter. Mejo ang sagwa lang kase tingnan. color yellow kase adaptor and yung rubber to the tube. nagmumuka tuloy cheap yung filter. hehehe...
or better yet baka may alam ka na autowarehouse that sells it.
thanks.
August 25th, 2007 06:59 PM #12
* Niky
thanks.
August 26th, 2007 12:03 AM #13
The fabricated ones I've seen are mostly "patok" steel... definitely cheaper looking than any plastic part.
You can try painting your adapter with high-temp paint... ;)
August 26th, 2007 09:54 PM #14
Ey niky, yung sinasbi mo ba na "patok" steel is the pic from the attached?
tagal na kase ko naghahanap ng ganong klase ng adapter.
correct me please if iam wrong, it is more prone sa air leak yung mga plastic elbow. where as, yung tunog ng filter would be... parang sumisingaw when you gas up kase possible na hindi nasukat ng tama yung size ng carb sa pagbutas ng plastic adaptor unlike kung steel adaptor yung nakakabit, it would be more compact and 100% intake.
August 28th, 2007 10:03 AM #15
Actually, whether plastic or rubber, there will be a rubber seal that mates the adapter to the carb, so leaks will be minimal.
- Aug 2006
- 152
August 28th, 2007 11:36 PM #16Sir here's some pics with simota and k&n airfilters for carbs! (Pics from grupotoyota.com and kotse.com)
Simota:
2k+ yata ang price nyan!
K&N:
5k+ naman ito!
high idle RPM at engine start
