Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    May 2005
    Just found the specs for the 4AFE ignition coil.
    Ignition Coil
    5. INSPECT PRIMARY COIL RESISTANCE
    Using an ohmmeter, measure the resistance between
    positive (+) and negative (–) terminals.
    Primary coil resistance (Cold):
    1.1 ~ 1.7 at –10 ~ +40°C (14 ~ 104°F)
    If the resistance is not as specified, replace the ignition
    coil.
    6. INSPECT SECONDARY COIL RESISTANCE
    Using an ohmmeter, measure the resistance between the
    positive (+) and high–tension terminals.
    Secondary coil resistance (Cold):
    9 ~ 15 k at –10 ~ +40°C (14 ~ 104°F)
    If the resistance is not as specified, replace the ignition coil.
    Check ko yung sakin. Baka nga ignition coil.
    Thanks!
    Feb 2009
    Quote Originally Posted by izzy View Post
    Thanks!
    Sometimes it passes the resistance check but fails miserably on spark test. The coil should be able to snap a bluish white spark from 3 inches to ground when tested. If the spark happens around the coil, the insulation had been breached
    Feb 2005
    Kasi nga ok pa daw. Tinesting nila Rey Electrical, malakas daw. Nakita ko, nag spark naman talaga.
    Then tinest din ng mekaniko na pinaikot daw yung distributor, may lumalabas naman daw sa wire. I didn't see this test personally, though.
    Kanina lang, shorted TE1 and E1, then turned on the key. Continuous blinking lang ang CEL. I guess that means ok ang mga sensors?
    imho, yung spark test indicator lang yan na may lumalabas na kuryente sa coil pero pag sinalpak mo na sa oto mahina naman buga ng kuryente, madaming beses nangyari sakin yan pag pinatesting ko yung coil via spark test ok daw malakas daw spark pero pag kinabit na sa oto ayun... nganga
    Baka namali ang firing order. Happened to my ST191 before. Nabiligtad ng mekaniko yung pin ng distributor.
    To test, bukas ng valve cover, itapat yung crankshaft pulley notch sa zero, ensure that no.1 cylinder is at compression TDC by ensuring that the pointed part of both its intake and exhaust camlobes ay nasa horizontal position or hindi nakaturo sa ilalim. At this position, yung distributor rotor e dapat nakaturo sa HTW ng no. 1 cylinder.
    Or try to test kung may voltage sa terminals ng fuel injectors. Troubleshooting a Toyota Fuel Injector | eHow
    Feb 2009
    i have used this on ignition performance diagnosis, it has never failed me.
    http://www.chevelles.com/techref/hei_files/image010.jpg
    May 2005
    I said, "To hell with it. Bibili ako ng surplus distributor! Doble gastos na kung doble gastos!"
    Kinabit, nag start. Problem solved! Thanks sa lahat ng comments/inputs! Next time, wag na iparepair, palit na lang ng buo.
98 Corolla 4AFE no spark
