Results 11 to 12 of 12
- Jan 2005
- 445
May 7th, 2010 10:04 AM #11Pag basa ng langis ung thread ng sparkplug ok lang un. Kapag tip ng sparkplug ang basa ibig sabihin tumatagas ang langis sa piston ring.
Kapag walang tagas sa mga seals ang makina at nagbabawas ng langis, ibig sabihin tumatagas ito sa piston ring.
Mabilis pa sya umandar pero nag babawas ng langis - 3 ang ring ng gasoline engine 1 - Compression ring 2 - Secondary compression ring 3- Oil controll ring. Maaring Compression rings 1 and 2 ay ok pero ung oil controll ring ang sira.
Mabilis pa sya umandar pero nag babawas ng langis - pede din sa valve seals galing ang langis ( in this case, you need to repair the cylinder heads valve guide / seals.
Para malaman mo kung sa valve seals galing ang langis paandarin mo ng mabilis habang pababa tapos bigla mong tanggalin paa mo sa accelerator pag umusok ng marami valve seal yan.
- May 2010
- 1
June 9th, 2010 10:53 AM #12pare, kung bore lng at overhaul, may mas mura akong ma aadvise sau, pare, txt me up, 16k is too much, or email me nlng, eric_salvador888*yahoo.com.
Just had a chat with a friend in upper management of Nissan Phil. They are releasing two new...
2025 Nissan Kicks
