Results 11 to 20 of 32
Tsikot Member Rank 3
- Dec 2002
- 636
June 18th, 2004 10:14 PM #11yup, 4JX1 sensitive in engine oil type and fuel quality. This is where coco diesel makes a difference- less smoke, more power.
June 19th, 2004 07:38 AM #12
this engione's sakit is the injectors will always f#*K u up. trust me guys, i know a lot of ppl who has a trooper with that same engine some 4x4, some 4x2, its always the same injector problem. the engine just suddenly would not start.
June 19th, 2004 09:33 AM #13
There is some cases where in tama si KCBOY (can't argue with that bro)
Pero the prob with 4JX1 engine though it is so powerful, fuel efficient the injection valves has problem.. medyo di kaya ang dumi nang fuel sa atin..
if I were to choose between a 4JX1 to 4Jg2 engine.. dito na ako sa latter.. kahit mahina ang HP niya pero napakadali i troubleshoot..
but still proper maintenance is still the key... medyo ultra migthy morphin sensitive ang injectors niyan... ewan ko ba nga naman sa diesel fuel natin...
June 19th, 2004 10:05 AM #14
what if they use diesel from the smaller oil companies, yung hindi locally refined diesel, mas cleaner ba yun? pati yung shell clean diesel ba di parin ganun ka-clean?
- 10,620
June 19th, 2004 10:39 AM #15boknoy,
kahit mahina ang 4JG2TDIC (125HP) sa 4JX1-TC (160HP)
adequate naman ang power niya
at di hamak naman na mas matulin siya kesa 2.5 at 2.8 na TDIC
- Aug 2003
- 1,251
June 19th, 2004 10:58 AM #16Originally posted by KCboy
Tsikot Member Rank 5
- 3,144
June 19th, 2004 11:02 AM #17kaya naman talaga, dalawang shell station ako nagpapakarga ng diesel, plus alaga talaga sa change oil
June 19th, 2004 07:55 PM #18
ur engine will not start period!!!!!!! once the injectors are screwed. time to pay up, 47,000 big ones. this was last year pa. im sure taas na yan....
- Aug 2003
- 1,251
June 20th, 2004 03:12 PM #19Given the experience (47,000 pesos), looking back, would you recommend pa rin getting this engine? Or the conscious effort required given the special oil needed plus the dirty pinoy diesel and cocodiesel option that means you have to put every fill up, are these enough to justify buying a trooper with this engine?
June 21st, 2004 08:28 AM #20
nope!!!!!!!the trooper was casa maintained all the way til now and ganun pa din ang nangyari. d kaya talaga ang dirty diesel. kaya i'm staying away muna from commonrail diesel engines.
