Page 1 of 2 12 LastLast
Results 1 to 20 of 32
    4jx1-tc - anyone tried using this engine?
    eto na po yong trooper engine, year since 2000
    yup. Trooper engine since at least 1999. It's a pretty powerful turbo-intercooler, multivalve, direct injection. Matipid din sa fuel consumption. Medyo mausok kung bibiglain mo.
  4. #4
    One of the best out there. 158 hp and Isuzu had this since 2000 sabi nga ni RedHorse.
    grabe sa tipid sa fuel!
    Signature
    Sir boybi,
    Mas matipid pa po ba itong engine na ito kaysa sa Patrol po ninyo? Just curious.
    roydok, correct ka dyan.
    Signature
    Aba si ERICDRED nandito na... ang Parokyano nang ISUZU sa kabilang himpilan... kamusta na sir....
    Bagong Insider natin sa ISuzu yan..
    As for the 4JX1-TC tama po kayo matipid yan at Common Rail pa
    Mar 2003
    mas matipid po ba 4jx1-tc sa sa smaller 2.8 mitsubishi 4m40?
    Aug 2003
    yung 03 trooper ng kaibigan ko, tumirik sa angeles, umabot ng 5K rpm,ayaw na bumaba. Hanggang ngayon, nasa shop pa. Tinanong ko yung kaibigan kong isuzu service advisor, duda niya baka overhaul na yan kasi affected ang injectors, although guess lang daw kasi di naman doon sa casa ng kilala ko pinasok. According to the casa naman saan pinasok yung trooper, marami na rin daw silang trooper with this engine na ganito ang problema. Ganun ka sensitive ang makinang ito?
    Dec 2002
    yup, 4JX1 sensitive in engine oil type and fuel quality. This is where coco diesel makes a difference- less smoke, more power.
    this engione's sakit is the injectors will always f#*K u up. trust me guys, i know a lot of ppl who has a trooper with that same engine some 4x4, some 4x2, its always the same injector problem. the engine just suddenly would not start.
    There is some cases where in tama si KCBOY (can't argue with that bro)
    Pero the prob with 4JX1 engine though it is so powerful, fuel efficient the injection valves has problem.. medyo di kaya ang dumi nang fuel sa atin..
    if I were to choose between a 4JX1 to 4Jg2 engine.. dito na ako sa latter.. kahit mahina ang HP niya pero napakadali i troubleshoot..
    but still proper maintenance is still the key... medyo ultra migthy morphin sensitive ang injectors niyan... ewan ko ba nga naman sa diesel fuel natin...
    what if they use diesel from the smaller oil companies, yung hindi locally refined diesel, mas cleaner ba yun? pati yung shell clean diesel ba di parin ganun ka-clean?
    boknoy,
    kahit mahina ang 4JG2TDIC (125HP) sa 4JX1-TC (160HP)
    adequate naman ang power niya
    at di hamak naman na mas matulin siya kesa 2.5 at 2.8 na TDIC
    Aug 2003
    Ano po nangyari sa mga kakilala mo na nagkaproblema sa injector nila? How did they fix the problem? Kasi I was basically decided to get a 2nd hand trooper, nagpapahanap ako sa bayaw ko, ayun, siya nagkwento tungkol doon sa trooper ng common friend namin. Sa inis niya, parang nagbitaw ng salita na ibebenta na lang daw niya. It's a 03 trooper. Meron na rin daw 02 trooper casa maintained so may options ako. But with what happened... back to square 1 na naman
    kaya naman talaga, dalawang shell station ako nagpapakarga ng diesel, plus alaga talaga sa change oil
    ur engine will not start period!!!!!!! once the injectors are screwed. time to pay up, 47,000 big ones. this was last year pa. im sure taas na yan....
    Aug 2003
    Given the experience (47,000 pesos), looking back, would you recommend pa rin getting this engine? Or the conscious effort required given the special oil needed plus the dirty pinoy diesel and cocodiesel option that means you have to put every fill up, are these enough to justify buying a trooper with this engine?
    nope!!!!!!!the trooper was casa maintained all the way til now and ganun pa din ang nangyari. d kaya talaga ang dirty diesel. kaya i'm staying away muna from commonrail diesel engines.
4jx1-tc engine
