Results 11 to 11 of 11
March 10th, 2005 04:35 PM #11
main advantage ng crdi (also applies to direct injection gas engines din ata), more precise control of the fuel (keeping in mind that diesels are compression-ignited) due to finer fuel atomization from high-tech and uber-expensive ultra-high pressure injectors. bottom line, more power
high idle RPM at engine start
