mga kapatid patulong naman po ako here is the story:
NISSAN SUNNY 1.3 sampalok engine 1990
after ko nabili yung sasakyan humahalo yung langis sa radiatorpinagtyagaan ko for several months hanggang makaipon pangbili pyesa at machine shop labor
so ganito na ginawa ko
stock engine, new valves seals and guide ( ako mismo bumili at nagpakabit sa machine shop), resurfaced cylinder head, new gasket (of course), replaced timing belt. tamang torque sequence at setting ng main bolt ng cylinder head base sa manual po.
0 degrees TDC yung piston then yung distributor is naka set sa sentro ng marking (adjusted a few cm para mag 10 deg BTDC)
tires are slim and standard 13' with 30psi palagi
FC ko after the above is i think 6-7 NLEX sya ha kasi meycauayan to edsa caloocan lang ang byahe ko
after several months of pagtiis eh naiinis na ako kasi 6km/l for a 1.3 engine on an expressway is i think bad! knowing light footed ako mag drive at laging naka 5th gear.
binuksan ko yung carb nakita ko 170 ang jet ng primary (sin laki ng pakong 1' ang diameter) at 60 yung secondary (gakarayom ang diameter) tama po ba yun? or nabaliktad nung unang may ari?
so ginawa ko
pinalitan ko ng 110 yung primary at still 60 pa rin yung secondary.
A/F mixture seems ok kasi yung plugs ko chocolate brown ang tip
then ngyn 4km/L na lang... lalong naging matakaw sa gas
after maubos yung 9 liters ko ng fuel (petron XCS) sinubukan ko ipagpalit yung 60 sa primary at yung 170 sa secondary at tinabi ko ulit yung 110 na binili ko baka sakali nagbaliktad lang ng may ari then adjust ulit ako ng A/F mixture
pakarga ulit ako petron XCS 9 liters.... gues what 4km/L pa rin...
hindi nagbabawas ng langis at ng tubig. hindi malagkit ang tail pipe ko wala usok sa dip stick at wala din talsik ng oil my brakes are ok
hose lang nakakabit sa carb nya is advancer at fuel line other than that wala na.
nag memekaniko din po ako and i've overhauled (both top and general) deisel engines, first time ko mag top overhaul ng gasoline engine of my nissan sunny sampalok engine. kasi napaka ironic naman kumpleto ko halos sa gamit tapos sa iba ko papagawa.
ano po posible na problema sa BAD fuel consumption ko? any help guys? mga experts sa carbs patulong...
hindi ko na hinahabol yung rumors na 12km/L ang nissan 1.3 engine kahit maging 9-10km/L man lang pwede na.
I know there is a solution for this kind of problem... hoping for the guys here makatulong...
) sabi ko kay wifey buksan muna window kasi baka mahilo tayo hehehe umalis na kami going to work (6.5Km from house to work) ayun naubos lang ng sasakyan 6.5Km is 750ml(nilagyan ko kasi ng pentel pen yung 250ml level, 500ml, 750ml, 1000ml, 1250ml at yung 1500ml using graduated cylinder na hiniram ko sa science lab ng anak ko
