in my opinion, i-disassemble ang makina hanggang sa crankshaft. then decide on the next move. too early to decide kung hanggang jan lang sa may tappets, camshaft ang nakita.
kasi kung ok pa yung crankshaft e rebuild na lang. yung pistons, con rods, other parts ay relatively easy to get kesa dun sa crankshaft.
sa sobrang tutong ng langis e bumara na oil pump.
Baka naman cooking Minola Fully Synthetic yung ginamit ng mekaniko dati.
Since you're changing the engine, change the assorted parts already (gasket kit, water pump, thermostat) and keep whatever parts you can get from the old engine as spare.
Ganda sana kung naka-score instead ng 1.8L engine instead of a 1.6 :D
Our 2007 Altis is at 120,000kms, runs on LPG and has a change oil every 5K (mineral). Compression is good and no signs of sludge when i checked before.
isip muna bro. i highly suggest reading a similar case sa Altis club zz (pa member ka sa site). It is a good read and well documented, may pictures din. tumirik sa SLEX, ang ending kelangan bumili ng bagong cylinder heads. parts pa lang 38k na, labor/cleaning 16k + miscellaneous pa.
link
Hi guys!
We opted for an easy way out kaya replace engine na lang and yun nga ano bang malay namen sa makina, also we will not keep the car anymore we'll sell it after ito maayos.
Mabawi man lang yung nagastos sa repair. Since ang hirap lagyan mg value yung car kung ibenta as is.
Problema pa pala, nawawala yung orig na CR neto.
Need ba yun pag nag request kami ng replacement of engine sa CR?
Paano ba? Request muna kami ng CR
Then after tsaka pa lang kami mag request ng engine number replacement? Or pwede isang lakaran na lang yun?
good day tsikoters. tanong ko lang kung meron kayo kilala na mekaniko o shop na mahusay gumawa ng altis 2005. naglinis kais ako ng spark plugs nung monday at nakita ko na meron konting langis sa plugs, ibig sabihin ay worn out na gaskets at o-ring ng engine, tama po? salamat sa makakatulong, yun pala hindi mataas ang labor kasi balak ko ako maghahanap ng parts![]()
sana me makatulong sa akin, alam ko need ng repair ang engine ko.top overhaul ay ok na kaya sa problema ko?![]()
Linisin mo muna plugs. Tapos gamitin mo car. Then check again yung spark plug. Minsan unburnt fuel lang yung basa sa spark plug.
Yung iba naman spark plug gasket lang, yung kasama sa valve cover.
Padiagnose mo muna (leak test, compression test, etc) para sigurado ka
salamat sir. meron mark ng langis din sa labas ng engine. meron po ba kayong alam na shop para macheck yung leak at compression ng engine?bago nga pala binigay sa akin yung car sabi ng bayaw ko nagbawas ng langis dati, high rev nga pala madalas ang driving style ni bayaw.sa akin wala pa naman bawas mga 2 months na rin. sensya na hindi ko pala nasabi lahat ng information sa unang post ko palang.hehe
Depende saan galing ang leak. Pa engine wash ka muna para alam saan galing leak although malamag VC gasket lang yan.
Di ako taga cavite. Cant help you for referral but if there is goodyear servitek in your area, try mo. From experience they are fairly decent with competent mechanics.
Sa las pinas pwede shell cradle
