Page 3 of 3 FirstFirst 123
Results 41 to 59 of 59
    #41
    Quote Originally Posted by anonemus View Post
    Curious lang ako: if regular 5K change oil routine was done, this wouldn't have happened, no?
    Right. Always do a regular change oil, what was given and stated interval in your vehicle owners manual. Panigurado, it will never happen like that.
    Sent from my UP+ using Tapatalk
    May 2009
    #42
    in my opinion, i-disassemble ang makina hanggang sa crankshaft. then decide on the next move. too early to decide kung hanggang jan lang sa may tappets, camshaft ang nakita.
    kasi kung ok pa yung crankshaft e rebuild na lang. yung pistons, con rods, other parts ay relatively easy to get kesa dun sa crankshaft.
    sa sobrang tutong ng langis e bumara na oil pump.
    #43
    Quote Originally Posted by rodetor View Post
    Just like what it looks on the picture of his cylinder head. Parang duon ka nagprito ng tocino. [emoji4]
    Baka naman cooking Minola Fully Synthetic yung ginamit ng mekaniko dati.
    Since you're changing the engine, change the assorted parts already (gasket kit, water pump, thermostat) and keep whatever parts you can get from the old engine as spare.
    Ganda sana kung naka-score instead ng 1.8L engine instead of a 1.6 :D
    Our 2007 Altis is at 120,000kms, runs on LPG and has a change oil every 5K (mineral). Compression is good and no signs of sludge when i checked before.
    Aug 2015
    #44
    isip muna bro. i highly suggest reading a similar case sa Altis club zz (pa member ka sa site). It is a good read and well documented, may pictures din. tumirik sa SLEX, ang ending kelangan bumili ng bagong cylinder heads. parts pa lang 38k na, labor/cleaning 16k + miscellaneous pa.
    link
    #45
    Hi guys!
    We opted for an easy way out kaya replace engine na lang and yun nga ano bang malay namen sa makina, also we will not keep the car anymore we'll sell it after ito maayos.
    Mabawi man lang yung nagastos sa repair. Since ang hirap lagyan mg value yung car kung ibenta as is.
    Problema pa pala, nawawala yung orig na CR neto.
    Need ba yun pag nag request kami ng replacement of engine sa CR?
    Paano ba? Request muna kami ng CR
    Then after tsaka pa lang kami mag request ng engine number replacement? Or pwede isang lakaran na lang yun?
    Mura ang 55k. Hope its a good one. Thats the easier route.
    #47
    Crossing our fingers bro.
    #48
    Quote Originally Posted by unmarked View Post
    link
    Bro may link ka sa exact thread? Hindi ba ito open for lurkers? Na parang tsikot, even non-members can read the thread?
    Aug 2015
    #49
    Sir I posted the link, unfortunately kelangan member ka e. pero madali lang magpa member, and you'll get so much info. prices quoted way back 2010, i think.
    Jun 2009
    #50
    The Club can also be accessed via the Tapatalk app, like Tsikot. No need to be a member if viewing lang
    #51
    Yey!
    Hanap mode nung thread. Ano kaya title?
    Aug 2015
    #52
    I didn't know pwede pala un LOL. search mo lang 'sludge'
    Sep 2016
    #53
    good day tsikoters. tanong ko lang kung meron kayo kilala na mekaniko o shop na mahusay gumawa ng altis 2005. naglinis kais ako ng spark plugs nung monday at nakita ko na meron konting langis sa plugs, ibig sabihin ay worn out na gaskets at o-ring ng engine, tama po? salamat sa makakatulong, yun pala hindi mataas ang labor kasi balak ko ako maghahanap ng parts
    Sep 2016
    #54
    Quote Originally Posted by dhenz76 View Post
    good day tsikoters. tanong ko lang kung meron kayo kilala na mekaniko o shop na mahusay gumawa ng altis 2005. naglinis kasi ako ng spark plugs nung monday at nakita ko na meron konting langis sa plugs, ibig sabihin ay worn out na gaskets at o-ring ng engine, tama po? salamat sa makakatulong, yun pala hindi mataas ang labor kasi balak ko ako maghahanap ng parts
    cavite area nga pala.hehe
    Sep 2016
    #55
    sana me makatulong sa akin, alam ko need ng repair ang engine ko.top overhaul ay ok na kaya sa problema ko?
    Jun 2005
    #56
    Linisin mo muna plugs. Tapos gamitin mo car. Then check again yung spark plug. Minsan unburnt fuel lang yung basa sa spark plug.
    Yung iba naman spark plug gasket lang, yung kasama sa valve cover.
    Padiagnose mo muna (leak test, compression test, etc) para sigurado ka
    Sep 2016
    #57
    Quote Originally Posted by sirkosero View Post
    salamat sir. meron mark ng langis din sa labas ng engine. meron po ba kayong alam na shop para macheck yung leak at compression ng engine?bago nga pala binigay sa akin yung car sabi ng bayaw ko nagbawas ng langis dati, high rev nga pala madalas ang driving style ni bayaw.sa akin wala pa naman bawas mga 2 months na rin. sensya na hindi ko pala nasabi lahat ng information sa unang post ko palang.hehe
    Jun 2005
    #58
    Depende saan galing ang leak. Pa engine wash ka muna para alam saan galing leak although malamag VC gasket lang yan.
    Di ako taga cavite. Cant help you for referral but if there is goodyear servitek in your area, try mo. From experience they are fairly decent with competent mechanics.
    Sa las pinas pwede shell cradle
    Sep 2016
    #59
    salamat ulit sir. pacheck ko sa restday ko. sana valve cover gasket nga lang, gusto ko tumagal sa akin ang car
2004 Altis suddenly Died. Engine Problem.
