Page 1 of 2 12 LastLast
Results 1 to 20 of 30
    Nov 2007
    how would one know when to change tha battery of your car in a timely manner. i just dont want my battery to conk out on me while i'm out of the house...
    tia everone
    Dec 2007
    Best way I think would be to invest in a voltmeter. If a battery can't crank out at least 13V of juice (correct me if I'm wrong), it's about time you get a new one. Batteries should usually provide 14.4V of push if I'm not mistaken.
    Or you could simply buy a new one every two years or so. Heat is supposedly a natural battery-killer.
    sir yuds, hate to do this to you pero may thread na about this...
    http://tsikot.yehey.com/forums/showthread.php?t=41609
    Jul 2006
    kapag hirap kana magstart the usual day tapos mapapansin mo ayaw magstart bigla.
    if moolah is not a problem to you, then you can do so every two years.
    but for people like me who scrimp on food everyday, i usually wait for it to die down on me. there are symptoms which tell you of the impending death of your battery.
    and yes, try to invest in a voltimeter.
    when your car doesn't start joke.. hehe
    well there are cars that has an indicator in the panel if the battery is out of charge..
    Quote Originally Posted by yudyin View Post
    tia everone
    Jan 2008
    Pa-test mo sa Motolite Service Center, pero dun ka bumili sa Suki mo Auto Supply mas mura dun kaunti, pwede mo pang i-benta luma mong baterya, doon mismo.
    Nov 2007
    these ar useful info guys! thanks
    Nov 2007
    these are useful info guys! thanks
    Nov 2007
    ano nga palang klaseng voltmeter bibilhin ko? and rough cost?
    Dec 2007
    Some of the Honda Club Phils' audio gurus have a digital voltmeter that plugs into the 12V cigarette lighter/power socket in the dashboard. Voltage is more critical to these people than most because they power loud audio systems.
    I don't know where you can get those (Banawe is your best bet I think) but they say it'll cost not more than PhP500. I'll ask.
    Dec 2007
    Update: PhP1200 pala yung plug-in voltmeter na kinukwento ko. You can get it at Team Car along Banawe cor. P. Florentino.
    merong ibat ibang rating ang car battery. votls, cranking amps,
    cold cranking amps, reserve capacity, amp hour etc. pero ang pinaka importante
    is volts and cranking amp. most of the time cranking amps ang bumababa kaya
    pag nasira yung battery nagtataka tayo kase gumagana pa yung ilaw, busina,radyo etc.
    kaya the best way is to have the battery checked at least twice a year ng tester na ma check
    yung volts and cranking amps.
    http://www.midtronics.com/search/sea...rytesters.aspx
    The battery of one of our vehicles was practically 'fried' recently because the regulator of its alternator broke down while I was driving, so it was putting something like 19V across the battery. The only manifestation is that the pilot lights on the dashboard were brighter and the radio was ouputing static.
    So, I have to change it eventhough it is still reflecting something like 12.6V on the voltmeter....
    5909:burn:
    Nov 2007
    great info guys
    Jun 2006
    5909:burn:
    buti hindi sumabog
    start having it check pag tapos na yun warranty ng batt mo...saka usually hinde na mag start ang car pag overnight na ka park the next morning ayaw na...so more or less pag nasa 2 yrs na yun batt mo yun dead na yun
    May 2005
    sa mga low maintenance ng battery, pag lagi mo bang nirerefill ng tubig mauubos pa din maski more than 2 years na?
    Feb 2006
    tia everone
    From experience, an indication that the battery is dying is a flickering sound when starting the engine. When this happens have your battery replaced ASAP
    HTH
    my batteries read 13.8 volts but still it wont start my car. I have to rush a mechanic to my place and when the series a battery, it does start. Well, i bought a new battery and will keep the old one and have it charge. next time i know what to do.
when to change batteries?
