Igniter IC type I think (as it's called Ignition Module - J152) => Amazon.com: Ignition Module for Mitsubishi M004 J152 C1959a E1928 6h1069 180-0256 01610 Cbe517 55-1569 Tp160 E730124910 19017012 27120-21020 27120-21050 Am15-18-v20 Md607814 Md611384 Lx-549: Automotive
Kapapalit ko lang ng Ignition Module before I posted this thread. Surplus nga lang dahil mahirap makahanap. (1,800 php) - 4,500 daw according sa isang Mitsubishi OEM dealer dito sa cavite kaso walang stock so nagtyaga sa surplus. I think okay naman kasi nun test malakas kuryente.
I've been checking resistance sa primary at secondary. I think this is what you meant by " Test mo kung may leak resistance between coil - terminal and ground. Pero disconnect mo muna yun coil + terminal for accuracy."
Primary - 1.25 ohms
seconary - 12.6 K ohms
It hasn't change even ilang beses na nag overheat at stall ang coil.
Updates:
Nag stall pa rin ako nun byahe ako Alabang to Walmart Arnaiz, although nag start naman agad pero wag lang mag AC.
May setup sa wiring is:
a.) Point A of ballast resistor connects "B" wire of the ignition module and 12v from ignition switch ON/RUN wire.
b.) Point B of ballast resistor to "+" of the ignition coil
c.) "C" wire of the ignition module to "-" of the ignition coil
basically ito sinunod ko -> http://www.mgbreakers.com/MGMart%20p...h%20Module.jpg
A friend says and a fellow tsikoteer did say na dapat yun line ng START eh nakakabit direcho sa "+" ng ignition coil para hindi mahirap mag start ng kotse.
What I think that something else could be wrong is the rotor armature. Binalik ko yung orig mitsubishi rotor, naalala ko kasi yun contact ng pinaka bilog eh iisa lang at manipis. Hindi tulad sa orig na 3 way sya. Pinilit ko kasi, it's hard to explain and I'll try to provide pictures for this.
I just replaced spark plugs na rin nga pala from NGK BP5ES to DENSO W16EX-U. Road-test it yesterday afternoon, so far hindi naging rough even tirik araw. Drove it, idle it (iniwan ko sa initan habang nabili ng relays haha) so far hindi tumirik.
The burn is very good naman sa lumang spark plugs. Ignition coil is Poong Soon orig korea part. Mahal kasi ng orig mitsubishi.. I'll try to post pictures ng coil at distributor.
I tried running it without ballast, 3 km pa lang ang init na ng ignition coil.
I tried it with ballast resistor, and parang matagal nga sya uminit.
Manual spec says 1.2 ohms primary at external resitor is 1.6 ohms, so 2.8 ohms lang required but I read it somewhere na dapat 3.5 ohms, at may posibility na magloko na at 3.0 ohms. Hope anyone can clear this up kasi nga may mga ignition coils na 3.0 ohms na agad resistance.
The actual test would be trying it sa traffic ng las pinas at edsa. I'll post what will happen next.
