Results 1 to 20 of 22
    May 2017
    A.) Using a 800 amp Booster Cable, If I am going to get power from a 700 amp (3SM) Battery, to power a lowly functioning 400 amp (1SM or 2SM)Battery, could it destroy the electrical components of the smaller car?
    B.) What if I use a 500 amp Booster cable, would the booster cable melt because of the higher 700amp (3SM) Battery?
    Thanks for the advise!
    A, you only destroy electrical components by swapping the red and black...
    May 2017
    Now I know thanks!
    Jul 2016
    no it wont melt your cable either of the two, 12v lang naman dumadaan dyan e, i suggest using the higher amp cable for better starting power.
    Sent from my Redmi 6A using Tapatalk
    it will get warm.
    ts
    get heavy duty ones. mine are rated 800 amps with plated clamps.
    it will get warm.
    ts
    Agree, they will just get warm....
    Current rating, of the transmission (booster cable in this case) should be guardbanded vs the current(power) rating of the source...
    May 2017
    Guardbanded means should have rubber-covered protection?
    Bro - what I meant by guardbanded is that it is rated some percentages higher than what is required....
    Others call it factor of safety but this time with a multiple of what's required.
    May 2017
    I see, what if you only use a 400 Amp Booster Cable VS a 500 AMP recipient Battery and a 700 Amp Battery ?
    Could the 400 Amp Booster Cable still transfer 500 AMP? or it would melt right away?
    A.)
    This depends on the Current required to start the vehicle... Since both batteries are in parallel, - assuming the receiving battery is not dead, then Current required from the source battery and through the booster cable is actually less...
    the electrical flow will be limited by what the electrical appliance will need.
    if it needs half an amp, then only half an amp will flow thru your big cables.
    errr...
    what do you intend to power with those cables, po?
    Nothing will melt or burn because you did not specify the amount of load. But normal car load would not even reach 100A in total so even a 100A cable should do just fine.
    You should also consider the resistance of the cable and the amount of load, apply Ohms and Kirchhoff's law to sum up to voltage drop.
    May 2017
    I see, I did not know that the recipient battery might need only less than 100A... So buying a 500A cable is already OK...
    Yes, but install fuse in between and disconnect solenoid for your safety. If what you are planning is a dual-bat setup for an RV, there is a kit for that including a regulator. Distance will also matter, the longer the distance the larger the wire gauge usually 6-8ga stranded-wire will do on a car.
    May 2017
    I only know is the ordinary booster cable, sorry I am not familiar with the fuse and solenoid and RV...
    Jan 2008
    Also make sure the alligator clips have a good grip / clamping force on the terminals..
    May 2017
    errr...
    just for emergency purposes only...
    for jumpstarting a dead battery? why didn't you say so the first time!
    ask the seller to show you a heavy-duty model.
    i have a cheap one i picked up at the mall, cheap. i have used it to jumpstart my diesel innova.
    if you are handy with your hands, or you know an electrician... you might even make your own set, using quality materials.
    i also have a cheap battery charger in the house. "for justin". just in case.
    May 2017
    I see many thanks tsikot friends!
    This is what I have, the KYK packaging says 500A battery jumpstart cable. The cable gauge looks like AWG 6(~14mm2), makapal lang balat so it looks thick. Good enough for quick jumpstarts.
    Below is a comparison of a 50mm2 and 22mm2 stranded cable.
Using a 800 amp Booster Cable to Power a 400 amp Battery
