Results 11 to 20 of 28
April 22nd, 2015 01:38 PM #11
sige doc, bili ako contact cleaner..... ang isa pang hindi ko nachecheck pala e yung wiring harness sa may hamba ng pintuan. parati pa naman nagfflex yun lalu na sa driver's side.
anyway, update uli ako sa susunod kung may progress na.
April 24th, 2015 04:21 PM #12
update:
nilinis ko na switches using contact cleaner (abro brand), smells like brake cleaner.
ayaw pa rin gumana. may nararamdaman akong click on the rear left switch. yung rear right e no feelings. stone cold.
nilinis ko rin master switch. ayaw din. pero yung power door locks gumagana pa rin naman.
yung front right window, ok pa rin naman. hoping tatagal pa iyon.
btw, di ko pa chineck yung wires sa may door jambs pero ok naman readings sa may harness side (yung connection sa may switch). so i think the wires on the door jambs are ok.
panahon na siguro para maghanap ng replacement switches.
April 24th, 2015 04:34 PM #13
tanong lang po, how do you fix yung issue na parang sumasabit yung glass pag pasara na? is there a special oil needed for this or pwede na yung Singer all purpose oil? thanks po
April 24th, 2015 05:09 PM #14
grasa at wd 40 ginamit ko sa guides, plastic pulleys at cables.
sa weatherstripping e diko mahanap (na naman) yung silicone grease ko. kaya yung microtex spray ang ginagamit ko pansamantagal. e binasa ko yung instructions nya e silicone din ang isa sa ingredients nya. so pupwede kako.
baka misaligned yung links, glass saddle ng iyo bro.
pero nangyari kahapon yan dun sa passenger side window ko. patigil tigil habang paakyat. baka connection issue or the motor itself. pero kung pababa e smooth naman. nung umandar makina e smooth naman na yung paakyat ng window.
April 24th, 2015 05:34 PM #15
12 volts ba talaga ang kelangan nung window motors? kung 12 volts e baka magpadesign at magpa-etch na lang ako ng pcb sa kaibigan kong ece....using the same switch (kasama na yung silicone pads). mas reliable na siguro yung ganun.
kung hinde e no choice kundi bumili ng kumplikadong electronic circuit board.
- Mar 2014
- 901
April 24th, 2015 06:21 PM #16
April 24th, 2015 06:35 PM #17
- Apr 2010
- 739
April 25th, 2015 12:43 AM #18Ganito rin halos yung problema ko, yung driver side umaakyat ng mag-isa minsan - pag nangyari ito inoperable na for sometime yung driver side window. Intermittent ito, minsan ok naman.
Nag trace na ako ng lines and so far ok naman, nagpalit na rin ako ng surplus motor since nasunog yung original ka, probably may connection dun sa issue na umaakyat mag isa.
Nilinisan at binaklas ko na rin yung master switch. Pumipitik naman yung relay pag cinocontrol ko yung driver side window pero di bumababa.
April 25th, 2015 10:33 AM #19
ok yung p/w relay nung akin. may konting init nga lang.
yung mga switch (master at rear left) e pumipitik pero poker face mga bintana.
after a serious analysis & troubleshooting (naks!), kumbinsido nako na yung mga switch ang problema ko.
dahil relative high current draw ang power window motors, ang isa sa nakita ko pang nagpalala ng problema e yung carbon tracking. lahat ng switch at harness meron neto. halos maubos na contact cleaner ko at leha kakalinis.
April 25th, 2015 10:35 AM #20
Xiaomi E-Car
