Results 1 to 20 of 28
    Oct 2013
    may auto up/down ba yan?
    Anyway check mo yung window lock switch, baka activated.
    May 2009
    Quote Originally Posted by vvti2.0 View Post
    may nakasulat na auto sa switch ng driver's side window. the rest wala. so meron, tama ba?
    regarding window lock switch, sinubukan ko rin. wala pa rin response sa bawat window kahit nakaunlock na.
    i suspect ok pa switch kahit na bopols ako sa electronics nun. kasi imposible naman sabay sabay bumigay.
    mapapatawad ko na yung motor ng driver side e busted na dahil most of the time yun ang nagagamit.
    recheck ko uli bukas. baka may nakaligtaan ako sa wiring checks ko.
    judging sa condition ng panel cover ng doors e may nagkutingting na pero hindi naman naabuso ang wiring.
    kabibili ko lang kase netong kabayo kong eto.
    May 2009
    update:
    rechecked all wiring harnesses. tugma lahat ng readings ko sa sinasabi ng troubleshooting manual.
    tapos biglang gumana na passenger side window. i don't know exactly kung pano nangyari. bukod sa ginawa kong wiring check (voltage & continuity) e niretorque ko yung bolt ng body ground sa may right kick panel (passenger).
    after the passenger front window, dumako nako sa rear right window. wiring checks fine (voltage & continuity). checked the motor continuity, zero ohms so therefore ok. further checked it by applying battery voltage to it, aba bumaba si bintana. nireverse ko polarity, lecheng motor ayaw umakyat. kinabahan ako dahil open parking tong location at the moment. nung nilubriicate ko sliding parts like the plastic pulleys, cables, guide, weatherstrip tapos pinukpok yung motor body e umakyat na ng walang kahirap hirap.
    kaso kapag gamit na yung switch e ayaw. rechecked the contacts, mukhang ok.
    regarding sa master switch (driver's), e parang may kumaskas na dati dun sa contacts ng circuit board.
    update:
    May 2009
    if all else fails, meron kaya nabibiling mechanical switch. i mean e yung simpleng switch na wala nang IC, diodes, resistors, capacitors , etc.?????
Troubleshooting my power windows
