rechecked all wiring harnesses. tugma lahat ng readings ko sa sinasabi ng troubleshooting manual.
tapos biglang gumana na passenger side window. i don't know exactly kung pano nangyari. bukod sa ginawa kong wiring check (voltage & continuity) e niretorque ko yung bolt ng body ground sa may right kick panel (passenger).
after the passenger front window, dumako nako sa rear right window. wiring checks fine (voltage & continuity). checked the motor continuity, zero ohms so therefore ok. further checked it by applying battery voltage to it, aba bumaba si bintana. nireverse ko polarity, lecheng motor ayaw umakyat. kinabahan ako dahil open parking tong location at the moment. nung nilubriicate ko sliding parts like the plastic pulleys, cables, guide, weatherstrip tapos pinukpok yung motor body e umakyat na ng walang kahirap hirap.
kaso kapag gamit na yung switch e ayaw. rechecked the contacts, mukhang ok.
regarding sa master switch (driver's), e parang may kumaskas na dati dun sa contacts ng circuit board.
update:
