Results 21 to 30 of 33
- Jan 2008
- 4,726
May 20th, 2018 10:47 AM #22
May 27th, 2018 03:01 AM #23
May 27th, 2018 10:24 AM #24
Check the voltage between the battery negative terminal and the headlight ground ( headlight ground) while the headlights are ON. If you read higher than 0.1 volts, you have bad ground.
May 27th, 2018 10:39 AM #25
It's your alternator ... it's not producing enough voltage to supply the vehicle and to charge the battery properly ... have the IC checked ... have it cleaned as well and replace the carbon brush ...
- 52,762
May 27th, 2018 10:51 AM #26yes, it does sound more like your alternator.
that should be easy to check. even the battery store should be able to do that.
- Dec 2017
- 1,018
May 27th, 2018 02:14 PM #27Like others have suggested, it's your alternator. One of the common symptoms of a bad alternator is dimming dashboard and headlights. It no longer has adequate power.
Maybe, you want to change electrician and hear another opinion.
Just in case:
Surplus alternator : P4,000 - P5,000
Brand new, Japan : P8,000+ (depends on car make)
- 52,762
May 27th, 2018 06:08 PM #28
- Jan 2008
- 4,726
May 27th, 2018 06:28 PM #29Hindi porke may contact its gonna work.. there are sometimes resistance in between contacts!
Na experience ko yan nung time na nag iinstall pa ako ng car stereo.. ang problem nung owner (mitsubishi spacewagon) everytime na ilalakas nya yung volume ng stereo nag flicker yung lights.. then mag shut off then on ulit to a lower volume.. guess what the culprit is..Fuse! Changed the fuse to a new one and voila flickering is gone and sound is back..
Alternator naman is easy to check.. voltage across the battery terminals should be 13.5 to 14v. At full load should be able to maintain at least 13.5v
- Dec 2017
- 1,018
May 27th, 2018 06:58 PM #30
I always do spirited driving on my way back home.
Hybrids and EV
