Results 1 to 4 of 4
- Jan 2018
- 21
June 16th, 2018 04:58 PM #1mga master, hingi lang sana ng tips... ano po ba magandang gawin sa starter solenoid connector yung tinutusok n connector medyo maluwang na sya kya hindi pure yung pasok ng kuryente pa nag start. pagnapadaan sa rudder na kalsada yung magvivibrate yung auto mo. pagstart mo ulit hirap na. kailangan itusok mo ulit para maganda yung connection. toyota revo 2003 model 7k engine gasoline.
June 16th, 2018 07:54 PM #2
- Feb 2015
- 28
June 17th, 2018 06:49 PM #3sorry i dont speak tagalog, im Australian, but i may be able to help.
I used google translate, and i think you have an issue where there is not a good power supply going to the engage terminal on the solenoid when the key is in start position.
A common problem.
A common solution worldwide is to run the solenoid from a separate relay, where the relay is activated by the wire which is normally plugged into "terminal 50" as jick mentions, which is connected the solenoid terminal (the male spade connector) straight to the battery, giving a good solid 12 volts to the solenoid magents, pulling the contacts together nice and close very hard.
here is a diagram.
https://www.yotatech.com/forums/atta...ps0606ef1a.jpg
the text ignition side refers to the wire that would normally go to the terminal 50
- Jan 2019
- 1
Xiaomi E-Car
