Results 1 to 8 of 8
- Nov 2008
- 51
September 7th, 2010 04:24 PM #1good day, ask ko lng if na experience nyo na un red light for hand break sa tabi ng speedometer eh ayaw mag off? kanina lang kc nangyari for unknown reason. Then minsan while running eh on & off sya minsan, pls help po kung ano magandang gawin bago dalhin sa mekaniko, i tried shutting off the engine pro ganun pa din. thanks
- Nov 2009
- 456
September 7th, 2010 06:07 PM #2Check if you have completely disengaged the hand brake. Check also the brake fluid reservoir in the engine compartment.
- Nov 2008
- 51
September 7th, 2010 09:08 PM #3Sir na disengaged ko ng ayos, I tried several time pero ganun pa din, but Sir tama ka bumaba ang brake fluid level, i dont know how kc every morning check ko sya like kanina umaga before I go, almost max sya kanina then ngyn nsa minimun na lang sya, lagyan ko na lang bukas bago umalis. Lately nga pla napansin ko nanginginig ang manibel evrytime nag pepreno ako, tinanong ko sa tire shop if klangang i-wheel align, not necessary daw kc bka brake pad?? pls enlighten sirs. thanks a lot.
- Nov 2009
- 456
September 7th, 2010 09:20 PM #4May leak somewhere yan kaya nabawasan ng fluid. Have it checked/fixed ASAP, preno yan. Also have the vacuum tubes leading to and from the hydrovac checked.
September 7th, 2010 09:47 PM #5
September 7th, 2010 09:49 PM #6
if no visible sign of fluid leak , use your sense of smell or maybe the fluid already dripping inside your hydrovac.
- Nov 2008
- 51
September 9th, 2010 11:36 PM #7Sir good day, for 2 days ginamit ko sya pro di nbabawasan ang brake fluid since nag refill, wla din trace ng leak.
- Jan 2016
- 6
January 12th, 2016 10:45 PM #8,, use your sense of smell or maybe the fluid already dripping inside your hydrovac." - try this one.
Good point on that. But the hybrid one which will give you a ton of savings on fuel maybe worth it...
Mitsubishi Xforce
