Results 1 to 8 of 8
August 13th, 2008 08:59 AM #2
Many factors - tire size, speedometer calibration, age of vehicle (and condition of mentioned parts), etc.
Most of the time the easiest way is to have the speedometer recalibrated.
Curious to know, how did you find out yours is not showing true vehicle speed?
August 13th, 2008 04:05 PM #3Curious to know, how did you find out yours is not showing true vehicle speed?
And was recently apprehended speeding inside a military camp. 10km/hr lang indicated ng gauge.
Vehicle all stock old Corolla.
January 22nd, 2014 06:56 PM #5
Reviving this thread just to share my recent downloaded Android app to be the most accurate among several free apps I downloaded. The best part I like is the big km/h digital display (mirrored HUD Heads-up display), where the reverse image is projected on your winshield, while your phone is just lying on your dashboard..
Check this out:
https://play.google.com/store/apps/d....android.tacho
*it works without depending on 3G/network data. only uses the standard GPS signal and its closely accurate with only ~2kph deviation with my Mitsu MS GLX speedo.
January 22nd, 2014 08:26 PM #6
January 28th, 2014 02:58 PM #7
sanayan at tantyahan nalang yaan, speedometer ko nasira din pero so far dipa naman hinuhuli ng pncc sa nlex at slex..
April 7th, 2014 11:56 AM #8
Sira na yung speedometer at tachometer ng AE101 Gli namin.
Ang gusto ko lang palitan yung mismong speedo at tacho then retain yung PHDM gauge housing, temp, fuel gauges and flex circuit board sa likod para same location ang mga gauges as before?
Compatible ba yung speedometer at tachometer ng mga JDM surplus gauges sa PHDM flexible circuit board w/o wiring modification?
Or is USDM gauge plug ang play without any wiring harness modification?
Xiaomi E-Car
