Page 1 of 2 12 LastLast
Results 1 to 20 of 45
    Aug 2014
    Hi Tsikoters,
    I just need your advise what could be the brand, type, specs of smallest battery that we can always carry specially on travel to start the Car. One time kasi, when I was stranded on a port waiting for the next Vessel to carry us going to the island,, sa kotse na ako natulog, nasagi ko yata switch ng head light, na drain yung battery, to the point na it cannot be started by pushing the Car, though someone help me to start the Car with his Battery. So i think next time, maybe better to carry a sort of portable battery that can use to start. Pwede kaya battery ng Motor?
    Feb 2009
    In this particular case you should have pulled the key out of the ignition, that way, the chime will sound off reminding you something is on that will drain the battery
    Prevention is better than cure in this case
    Aug 2014
    My ride is using the negative source, and does not have the chime to alert me of something, I dont actually have the key inserted during that time, so if I accidentally trigger the head light and fall a sleep, then, unless someone woke me up. (older car and no extra feature), its not actually a cure, its an alternative, on instances that no vehicle can help to jump start. Anyway thanks for the input.
    First hinde ko alam paano nag-on headlight mo kung nasagi lang. Second you don't need small battery specifically meron mabibili ng mga car booster
    Aug 2014
    car booster, thank, i'll search for that.
    I can turn the headlight on with out the key. Sa pagkaalala ko, nasagi ng paa ko, yung tulog na iakyat mo paa mo sa dash :P
    May 2009
    Quote Originally Posted by aioshin View Post
    parang di ako bilib sa mga car booster na iyan....mas okey pa ako sa jumper cables at singkwenta pesos (pangyosi ng magdodonate ng extra dugo sa battery)
    Aug 2014
    meron na ako nung jumper cable, kaya lang, di ko dinala that time, kasi nga kala ko tulak lang, ayos na. Pero di pala dapat sobrang drain yung Battery, kahit tulak di aandar. btw, 4ja1 yung makina.
    Aug 2003
    Gamit ko Anker powerbank pang jump start. Tested ko na sa Revo 1.8 gas. Meron sa CDR king pero not sure kung same quality.
    Feb 2009
    Chances are, even if you have the best power booster that you will forget to bring it. You're better off installing a battery master disconnect
    Aug 2014
    I'll try that option. For now, I just need to have an extra and portable battery or jump starter.
    Dec 2014
    Like this Black and Decker power booster
    Oct 2013
    Batterya ng cellphone..
    Pantawag sa motolite o sa kaibigan mo nearby para magdala ng batterya or sasakyan at pang jump start.
    Pantawag sa motolite o sa kaibigan mo nearby para magdala ng batterya or sasakyan at pang jump start.[/QUOTE]
    i always have this option!
    then one day... it happened..
    and waddayunow... nandoon sa lumang cellphone ko yung number! kapapalit ng cellphone unit... hindi na-transfer!
    Aug 2012
    Murphy's Law: Anything that can go wrong, will go wrong.
    Quote Originally Posted by red_one View Post
    modified murphy's law:
    anything that can go wrong, will go wrong. and it will be at such conditions as to cause the most damage, inconvenience, or embarassment.
    ... works every time in my field..
    Feb 2009
    Hence the prevention of recurrence. A doctor can only try and hope if the patient's body does not respond to medication
    everyone already knows how to prevent recurrence. not everyone knows how to start an engine with a dead battery.
    and if my patient's body does not respond to medication, i change the medication. i'm not about to be defeated by a bug that's smaller than my sperm cells..
    i laud your passion for pro-activity.. but in this thread, i feel you may be barking up the wrong tree.. but who knows... someone might get ideas from what you planted..
    Feb 2009
    I admire this positive mental attitude. Perhaps you could join the quest to stop Ebola and find the cure.
    BTT so you won't forget to turn the battery disconnect, you can opt to put loads other than memory loads through a 30 amp make type relay activated by the ignition switch
    Jun 2005
    if i remember correctly, may post si james deakin that the battery on his escape died on him.
    a technician was called and jump started the car by using a gadget same size of a power bank. hehe.
    BTT, i'll just bring my jumper cables and ask taxi to jump start my car. pay 50 petot for the service. tapos.
    Jun 2006
    Thats capacity, some lipos are capable up to 60c. It started my vvti innova and vios. Parasitic drain of my amps tends to drain my batts if i dont use the car for more than a week.
Smallest Emergency Battery that can be use to start the our car
