Results 1 to 10 of 45
- Aug 2014
- 391
April 11th, 2015 07:39 AM #1Hi Tsikoters,
I just need your advise what could be the brand, type, specs of smallest battery that we can always carry specially on travel to start the Car. One time kasi, when I was stranded on a port waiting for the next Vessel to carry us going to the island,, sa kotse na ako natulog, nasagi ko yata switch ng head light, na drain yung battery, to the point na it cannot be started by pushing the Car, though someone help me to start the Car with his Battery. So i think next time, maybe better to carry a sort of portable battery that can use to start. Pwede kaya battery ng Motor?
April 11th, 2015 08:19 AM #2
In this particular case you should have pulled the key out of the ignition, that way, the chime will sound off reminding you something is on that will drain the battery
Prevention is better than cure in this case
April 11th, 2015 08:31 AM #3
First hinde ko alam paano nag-on headlight mo kung nasagi lang. Second you don't need small battery specifically meron mabibili ng mga car booster
- Aug 2014
- 391
April 11th, 2015 08:31 AM #4My ride is using the negative source, and does not have the chime to alert me of something, I dont actually have the key inserted during that time, so if I accidentally trigger the head light and fall a sleep, then, unless someone woke me up. (older car and no extra feature), its not actually a cure, its an alternative, on instances that no vehicle can help to jump start. Anyway thanks for the input.
- Aug 2014
- 391
April 11th, 2015 08:34 AM #5car booster, thank, i'll search for that.
I can turn the headlight on with out the key. Sa pagkaalala ko, nasagi ng paa ko, yung tulog na iakyat mo paa mo sa dash :P
April 11th, 2015 08:44 AM #6
parang di ako bilib sa mga car booster na iyan....mas okey pa ako sa jumper cables at singkwenta pesos (pangyosi ng magdodonate ng extra dugo sa battery)
- Aug 2014
- 391
April 11th, 2015 08:48 AM #7meron na ako nung jumper cable, kaya lang, di ko dinala that time, kasi nga kala ko tulak lang, ayos na. Pero di pala dapat sobrang drain yung Battery, kahit tulak di aandar. btw, 4ja1 yung makina.
- Aug 2003
- 20
April 11th, 2015 08:52 AM #8Gamit ko Anker powerbank pang jump start. Tested ko na sa Revo 1.8 gas. Meron sa CDR king pero not sure kung same quality.
April 11th, 2015 09:00 AM #9
Chances are, even if you have the best power booster that you will forget to bring it. You're better off installing a battery master disconnect
- Aug 2014
- 391
Xiaomi E-Car
