Results 11 to 17 of 17
November 1st, 2009 11:23 PM #11
ok, let me continue this thread kasi ako kasama niyan nung ginagawa namin yan kasi.
so ganito mga sirs, fuse number 15, which is yun park light ang pumuputok. as for the car, civic FD 2007 1.8s ang kotse.
ganito kasi, nirereplace namin yun flashing problem circuit ng civic kahapon. ang problema, bigla nalang total shutdown ang park lights nung naka-on ang park lights at nag-flash kami. eh based naman sa diagram, hindi naman puputok ang park light fuse dahil separate naman siya sa high beam. so paano nangyari yun? hanggang ngayon, yan ang iniisip ko... so please lang po, paki-tulungan niyo friend ko, thanks...
November 2nd, 2009 12:24 AM #12
Is the "flashing" circuit you guys added the one that allows you to flash the high beams without flashing the low beams, presumably to protect the HID ballast?
Please post the wiring diagram you guys used. And also which Civic FD electrical diagram are you using as reference? I know that there were several different versions of it wherein the fuse locations were slightly different.
November 2nd, 2009 05:35 AM #13
yun nga oj, yun flashing circuit to protect the hid. ang reference namin, is the one found at team fd pero with the additional na nilagyan ko ng relay na rin yun high beam
THE AUTO SPECIALIST
- Mar 2006
- 607
November 2nd, 2009 06:53 AM #14some cases kailangan ng scanner para ireset yung light control module . pero im going to post you the tech info as soon as possible .
i have a complete tech info at disposal ,coverage up to 2008 .
- Jul 2009
- 6
November 2nd, 2009 10:39 AM #16thanks sa mga tulong ninyo... i finally figure it out... naayos ko na po...
paki close na po ung thread...
high idle RPM at engine start
