Results 1 to 10 of 14
- Aug 2008
- 6
August 26th, 2008 09:58 PM #1hi there, newbie here. i have a honda lx 94 and though it has a new battery (barely 4months) it will not start after i have not used it for 2 or 3 days or so. i have another car, a 96 GLI and i dont have a problem with is even if i dont use it for a week.
could this be an alternator problem? or a battery issue?
help please... thanks
THE AUTO SPECIALIST
- Mar 2006
- 607
August 27th, 2008 06:54 AM #2there are some things to do here ( NO CRANK)
check for current draw / should'nt be more than .050 Amp
if ok go to next step
disconnect neg battery cable and leave the car sitting for three days
if the car won't start,battery problem
may consider to bring it to your trusted auto electrical shop
August 27th, 2008 10:00 AM #3
sir mukhang sa grounding me problem?? ahm pag ba naka start then biyahe ka like mall tapos pinatay mo after 1 min start mo ulit hirap ba istart o hindi>?
August 27th, 2008 10:00 AM #4
- Aug 2008
- 6
August 28th, 2008 11:52 AM #5girl po ako
but anyway thank you for you replies
uh that's what we try to do if we dont get to use the car for a few days, disconnect the negative battery cable, and it wont have any problem starting.
yesterday, it wont start and we had to jumpstart it using our van's battery. it wont start coz i havent used it for 3 or 4 days and i forgot to disconnect the negative battery cable.
kapag nastart ko na sya and mainit na ang makina, no problem starting it again. only when tha car is idle for 2 days or so.
thoughts??
THE AUTO SPECIALIST
- Mar 2006
- 607
August 28th, 2008 12:12 PM #6you definitely have a wiring problem
a current draw of more than .050 amp is not good to the battery
get it checked by an auto electrician
they should be able to correct it
August 28th, 2008 01:33 PM #7
btw, what do you mean hindi nagstart after days of not using it? pero may redondo nung nagtry ka istart? malakas o none at all?
before nung may kotse pa ako powered by gasoline engine may naging problem din ako sa starting and lately we found out na fuel pump ang culprit not the bat or alt.
August 28th, 2008 03:04 PM #8
yup pwedng tama si sir esnie pero kung fuel pump diba me posibly na mamatay ang makina habang tumatakbo?
mas maganda nyan ate dalhin mo na lang sa auto electrician o kaya antayin natin ang ibang tsikoters
August 28th, 2008 04:33 PM #9
Sir aga yung nangyari sa auto ko kapag hindi ginamit doon lumalabas ang sira ayaw magstart pero once na napa-start na kahit matagal na naka-idle ay okay naman. Yung problem ni starfire maraming possible causes dapat madetermine kung nagkakaroon ng redondo or totally wala, kung meron man redondo malamang sa fuel system or sa distributor.
August 28th, 2008 06:08 PM #10
ate me redondo ba pag iniistart nyo? o totally click lang?kung me redondo malamang fuel pump ang sira
pag click lang at mahina ilaw ng panel board malamang groundings lool like na parang dinidiskarga nya ang battery ng otto?
Do you think there's still ambiguity given my post here:...
1st LTO renewal after 3 yr registration
