Results 21 to 30 of 30
- Aug 2014
- 3
February 27th, 2015 02:48 PM #21same sa bighorn ko mga ka tsikot..minsan aandarin ko madali siya mg start.. after a minute off mu siya...start mu ulit ayw na mg start..stand by lng ng kahit 20 minutes gagana na namn siya...3 dyas pa lng battery ko...palit na rin ako ngalternator ok namn starter ko.. ano kya probs nito mga sir..TIA...
February 27th, 2015 03:20 PM #22
armateur mo sir, baka grounded.. pag mainit ang makina, mahirap mag start. pero kung malamig ang makina, 1 click lang yan.
- Mar 2014
- 901
February 27th, 2015 08:08 PM #23Try checking your ignition switch too.
Sent from my Starmobile UP+ using Tapatalk
- Apr 2009
- 100
April 20th, 2015 02:34 AM #24
- Oct 2013
- 1,181
April 20th, 2015 06:51 AM #25Wala connection ang power supply nyan, sa fuel distribution issue mo nyan.
Basta napaikot ng battery mo ang starter at narinig mo na napaikot naman ng starter mo ang ring gear, hindi electrical yan.
Check your fuel pressure regulator. Di pumapasok ang fuel mo dahil mataas ang temperature ng makina therefore creating a high pressure.Last edited by vvti2.0; April 20th, 2015 at 07:47 AM.
- 54,291
April 20th, 2015 09:08 AM #26starter solenoid.. ignition solenoid (yung maliit lang na nasa engine bay; it's not too expensive.. replace it)... starter carbon brushes.. AND the ignition electrical switch.!
- Apr 2015
- 140
April 20th, 2015 09:57 AM #27Ganyan din problema sa pajero gen2 diesel ko. Kaoag baging patay ang makina taposs after mga 3-5 mins istart mo ulit, parang may pumipigil sa ikot ng starter. Pero pag binabad mo sa start ung susi iikot naman siya pero alam mong pigil ang ikot hund tulad pag cold start o mejo malamig na an makina. Ano kaya problema?
- Apr 2009
- 100
April 24th, 2015 12:22 PM #28
Lahay po yan sir pinalitan na yan po kasi basically gagawin ng mga electrician natin pag may problema starter. .
Clear ko lang po detailed problem ng sasakyan namin. .
1. Cold start 1 click lang pag uminit na makina mga 1hr driving pag kailangan mo start ang sasakyan at pagpihit po ng ignition key walang response po sa starter click lang po naririnig ko. . Walang crank or redondo. .
Na check na rin po lahat ng wirings ng sasakyan kaya hndi rin alam ng electrician ano gagawin kc napalitan na halos lahat ng component ng sasakyan. .
Try ko gawin ung suggestion tungkol dun sa armature baka nga kailangan na irewind. .
April 25th, 2015 11:35 AM #29
some problems ay simple lang ang solution some need more comprehensive diagnostics. medyo magulo na ang thread kaya di ko alam kung nasabi mo na kung ano ng car pinag uusapan natin (model, matic or manual). usually mas madali mag diagnose sa starter relay, do you have power sa relay at on and start position, meron ba ground supply sa relay coil ground ito ay galing mostly sa park-neutral safety switch or trans range sensor pag matic pag manual kung minsan may pedal switch. if the relay test passed punta ka sa supply ng starter and solenoid (kung alam mo voltage drop testing the better). pag pasad uli oras na para ibaba ang starter for repair or replacement. sa comprehensive diagnostic naman ay pinaka maganda gumamit oscilloscope(with current probe para makita mo status ng armature).
- 54,291
April 25th, 2015 11:50 AM #30
parang some of the countdown timers along taft ave manila, aren't functioning today... or am i...
SC (temporarily) stops NCAP
